2015-04-11, 07:37
(2015-04-11, 07:27)insertnamehere Wrote: [ -> ](2015-04-11, 06:14)thekow Wrote: [ -> ]Plugin was working perfectly until i tried to watch daredevil it comes up with "busy" then script failed! on 3.18 it only fails on daredevil.
Code:13:57:26 T:2431294272 NOTICE: -->Python Interpreter Initialized<--
13:57:26 T:2431294272 NOTICE: URL: https://www.netflix.com/Login
13:57:27 T:2431294272 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:79: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL $
13:57:27 T:2431294272 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strong$
InsecureRequestWarning)
13:57:28 T:2431294272 ERROR: Previous line repeats 2 times.
13:57:28 T:2431294272 NOTICE: URL: https://signup.netflix.com/Login
13:57:28 T:2431294272 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:79: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL $
13:57:29 T:2431294272 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strong$
13:57:30 T:2431294272 ERROR: Previous line repeats 2 times.
13:57:30 T:2431294272 NOTICE: Setting Country: AU
13:57:30 T:2431294272 NOTICE: URL: https://www.netflix.com/WiHome
13:57:30 T:2431294272 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strong$
13:57:34 T:2439686976 NOTICE: Thread BackgroundLoader start, auto delete: false
14:00:38 T:2777676608 NOTICE: Thread JobWorker start, auto delete: true
14:00:38 T:2695887680 NOTICE: Thread LanguageInvoker start, auto delete: false
14:00:38 T:2695887680 NOTICE: -->Python Interpreter Initialized<--
14:00:39 T:2505943872 NOTICE: Thread BackgroundLoader start, auto delete: false
14:00:39 T:2505943872 NOTICE: Thread JobWorker start, auto delete: true
14:00:46 T:2695887680 NOTICE: Thread LanguageInvoker start, auto delete: false
14:00:46 T:2695887680 NOTICE: -->Python Interpreter Initialized<--
14:00:46 T:2695887680 NOTICE: URL: https://www.netflix.com/MyList?leid=595&link=seeall
14:00:46 T:2695887680 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:79: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL $
14:00:47 T:2695887680 ERROR: /home/super/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/connectionpool.py:769: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strong$
14:00:50 T:2695887680 WARNING: GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '' as 0 minutes
14:00:50 T:2677009216 WARNING: Previous line repeats 13 times.
14:00:50 T:2677009216 NOTICE: Thread BackgroundLoader start, auto delete: false
14:00:57 T:2695887680 NOTICE: Thread LanguageInvoker start, auto delete: false
14:00:57 T:2695887680 NOTICE: -->Python Interpreter Initialized<--
14:00:58 T:2695887680 NOTICE: URL: http://api-global.netflix.com/desktop/odp/episodes?languages=en-AU&forceEpisodes=true&routing=redirect&video=80018294&country=AU
14:00:58 T:2695887680 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: No JSON object could be decoded
File "/home/super/.kodi/addons/plugin.video.netflixbmc/default.py", line 1234, in <module>
listSeasons(name, url, thumb)
File "/home/super/.kodi/addons/plugin.video.netflixbmc/default.py", line 441, in listSeasons
content = json.loads(content)
File "/usr/lib/python2.7/json/__init__.py", line 338, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Tried it on 1.3.14 and also fails, just Marvel's Daredevil
The request sent by Netflixbmc to Netflix for Daredevil looks like this and if you put it through a browser it fails at the Netflix server.
"http://api-global.netflix.com/desktop/odp/episodes?languages=en-AU&forceEpisodes=true&routing=redirect&video=80018294&country=AU"
The next request is a valid that returns valid data from the netflix server.
"http://api-global.netflix.com/desktop/odp/episodes?languages=en-AU&forceEpisodes=true&routing=redirect&video=80037657&country=AU"
Apart from the videoID (80037657) there is no difference between. All the other series work ok.
It looks like the problem is with Netflix server.
i just tried daredevil and got the same issue
So a stack trace on that one:
com.netflix.hystrix.exception.HystrixRuntimeException: NDCMapODPGetConfig failed and fallback failed.
at com.netflix.hystrix.AbstractCommand$16.call(AbstractCommand.java:792)
at com.netflix.hystrix.AbstractCommand$16.call(AbstractCommand.java:769)
at rx.internal.operators.OperatorOnErrorResumeNextViaFunction$1.onError(OperatorOnErrorResumeNextViaFunction.java:77)
at rx.internal.operators.OperatorDoOnEach$1.onError(OperatorDoOnEach.java:70)
at com.netflix.hystrix.AbstractCommand$DeprecatedOnFallbackHookApplication$1.onError(AbstractCommand.java:1444)
at com.netflix.hystrix.AbstractCommand$FallbackHookApplication$1.onError(AbstractCommand.java:1334)
at com.netflix.hystrix.HystrixCommand$2.call(HystrixCommand.java:314)
at com.netflix.hystrix.HystrixCommand$2.call(HystrixCommand.java:306)
at rx.Observable$1.call(Observable.java:144)
at rx.Observable$1.call(Observable.java:136)
at rx.Observable.unsafeSubscribe(Observable.java:7495)
at rx.internal.operators.OperatorOnErrorResumeNextViaFunction$1.onError(OperatorOnErrorResumeNextViaFunction.java:78)
at com.netflix.hystrix.AbstractCommand$HystrixObservableTimeoutOperator$3.onError(AbstractCommand.java:977)
at rx.internal.operators.OperatorSubscribeOn$1$1$1.onError(OperatorSubscribeOn.java:71)
at com.netflix.hystrix.AbstractCommand$DeprecatedOnRunHookApplication$1.onError(AbstractCommand.java:1403)
at com.netflix.hystrix.AbstractCommand$ExecutionHookApplication$1.onError(AbstractCommand.java:1303)
at com.netflix.hystrix.HystrixCommand$1.call(HystrixCommand.java:297)
at com.netflix.hystrix.HystrixCommand$1.call(HystrixCommand.java:289)
at com.netflix.hystrix.AbstractCommand$5.call(AbstractCommand.java:518)
at com.netflix.hystrix.AbstractCommand$5.call(AbstractCommand.java:501)
at rx.internal.operators.OperatorSubscribeOn$1$1.call(OperatorSubscribeOn.java:62)
at com.netflix.hystrix.strategy.concurrency.HystrixContexSchedulerAction$1.call(HystrixContexSchedulerAction.java:56)
at com.netflix.hystrix.strategy.concurrency.HystrixContexSchedulerAction$1.call(HystrixContexSchedulerAction.java:47)
at com.netflix.lang.BindingContexts.callWithContext(BindingContexts.java:204)
at com.netflix.lang.ContextCallable.call(ContextCallable.java:72)
at com.netflix.logging.aspects.LoggingContextWrappedCallable.call(LoggingContextWrappedCallable.java:75)
at com.netflix.hystrix.strategy.concurrency.HystrixContexSchedulerAction.call(HystrixContexSchedulerAction.java:69)
at rx.internal.schedulers.ScheduledAction.run(ScheduledAction.java:55)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.netflix.hystrix.exception.HystrixRuntimeException: The callServer stage for command NDCMapODPGetConfig failed. RequestId [ 8607847e-e809-4416-bb22-b983061527cd-5576971 ] Debug Info [ { "video":80018294, "country":"{ISOCountry/NFCountry#AU}", "locale":"en-US", "include":{"design":["www"]}, "exclude":{} } ]
at com.netflix.map.service.impl.MapClientDependencyCommand.handleProcessFailure(MapClientDependencyCommand.java:517)
at com.netflix.map.service.impl.MapClientDependencyCommand.callServer(MapClientDependencyCommand.java:456)
at com.netflix.map.service.impl.MapClientDependencyCommand.run(MapClientDependencyCommand.java:196)
at com.netflix.hystrix.HystrixCommand$1.call(HystrixCommand.java:294)
... 24 more
Caused by: java.lang.IllegalStateException: Map Server returned status code: 500 for server:map:7001
at com.netflix.map.RestRequest.execute(RestRequest.java:237)
at com.netflix.map.RestRequest.get(RestRequest.java:196)
at com.netflix.map.service.impl.ODPGetConfigClient.callServer(ODPGetConfigClient.java:135)
at com.netflix.map.service.impl.MapClientDependencyCommand.callServer(MapClientDependencyCommand.java:437)
... 26 more
Caused by: java.lang.IllegalStateException: Server response:
{"error":"java.lang.RuntimeException: com.netflix.map.MapException: The process stage for command ODPGetCompositeResult failed. RequestId [ 94411a4a-f153-4bf0-9c1b-9598ce5ad42d ] Debug Info [ Video:{Video/TrivialVideo#80018294} FilterInclude:{\"movieId\":[\"80018294\"],\"videoId\":[\"80018294\"],\"phases\":[\"2\"],\"phase\":[\"2\"],\"design\":[\"www\"]} FilterExclude:{} ]"}
at com.netflix.map.RestRequest.execute(RestRequest.java:231)
... 29 more
The funny thing is the json output is actually returned.
There is not much we can do about this, hopefully netflix will fix it soon
