Hi Folks,
I have been doing a lot of research and persevering with this to get it running and simply cannot get it to go. I have Kodi Helix installed on my desktop (Linux Mint 17.1) and a dedicated media centre on Windows 7 Ultimate. Chrome is installed on both. I am able to start the addon which appears to login and can get select Movies, TV or Search. After that, I always get "Script Failed" errors. This is the same for both systems.
Here is a log file snippet from my Linux machine, I am hoping there is enough info in here to help get this resolved. Thank you.
13:07:32 T:139986839521024 NOTICE: -->Python Interpreter Initialized<--
13:07:33 T:139985583855360 NOTICE: Thread FileCache start, auto delete: false
13:07:33 T:139986839521024 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 500: Internal Server Error
File "/home/richard/.kodi/addons/plugin.video.netflixbmc/default.py", line 977, in <module>
listVideos(url, type)
File "/home/richard/.kodi/addons/plugin.video.netflixbmc/default.py", line 140, in listVideos
content = opener.open(url).read()
File "/usr/lib/python2.7/urllib2.py", line 410, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 448, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 500: Internal Server Error
13:07:33 T:139987368511424 ERROR: GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=movie&url=http%3a%2f%2fwww.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson
13:07:33 T:139987368511424 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&type=movie&url=http%3a%2f%2fwww.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
13:07:33 T:139986839521024 NOTICE: Thread LanguageInvoker start, auto delete: false
13:07:33 T:139986839521024 NOTICE: -->Python Interpreter Initialized<--
13:07:33 T:139984555243264 NOTICE: Thread BackgroundLoader start, auto delete: false
13:07:34 T:139985583855360 NOTICE: Thread FileCache start, auto delete: false
13:07:38 T:139985160222464 NOTICE: Previous line repeats 5 times.
13:07:38 T:139985160222464 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
13:07:38 T:139985160222464 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
13:07:38 T:139985160222464 ERROR: Open - failed to open source <https://icanuckxbmcrepo.svn.cloudforge.com/icanuckxbmcrepo/trunk/addons.xml.md5>
13:07:38 T:139985160222464 ERROR: Failed to fetch checksum for directory listing
https://icanuckxbmcrepo.svn.cloudforge.c...addons.xml for repository repository.icanuck.
13:07:38 T:139985583855360 NOTICE: Thread FileCache start, auto delete: false
13:09:13 T:139986925655808 NOTICE: Previous line repeats 13 times.
13:09:13 T:139986925655808 NOTICE: Thread LanguageInvoker start, auto delete: false
13:09:13 T:139986925655808 NOTICE: -->Python Interpreter Initialized<--
13:09:13 T:139985160222464 NOTICE: Thread BackgroundLoader start, auto delete: false
13:09:13 T:139985185400576 NOTICE: Thread JobWorker start, auto delete: true
13:09:14 T:139986925655808 NOTICE: Thread BackgroundLoader start, auto delete: false
13:09:32 T:139987368511424 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
13:09:32 T:139987368511424 NOTICE: Enabled debug logging due to GUI setting. Level 2.
13:09:32 T:139987368511424 DEBUG: ------ Window Init () ------
13:09:32 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:33 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:33 T:139987368511424 DEBUG: LIRC: Update - NEW at 157926:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:09:34 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:09:34 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:34 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:36 T:139987368511424 DEBUG: LIRC: Update - NEW at 160659:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:09:36 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:09:36 T:139987368511424 DEBUG: ------ Window Init (DialogSelect.xml) ------
13:09:36 T:139987368511424 INFO: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
13:09:36 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:37 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:43 T:139987368511424 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-x86_64-linux.so)
13:09:43 T:139987368511424 DEBUG: Unloading: /ImageLib-x86_64-linux.so
13:09:44 T:139987368511424 DEBUG: ProcessMouse: trying mouse action wheeldown
13:09:44 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:49 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:49 T:139985185400576 DEBUG: Thread JobWorker 139985185400576 terminating (autodelete)
13:09:49 T:139987368511424 DEBUG: ProcessMouse: trying mouse action wheelup
13:09:49 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:51 T:139987368511424 DEBUG: Previous line repeats 4 times.
13:09:51 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:52 T:139987368511424 DEBUG: LIRC: Update - NEW at 176159:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:09:52 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:09:52 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:52 T:139987368511424 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
13:09:52 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:09:55 T:139987368511424 DEBUG: LIRC: Update - NEW at 180142:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:09:56 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:09:56 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:09:56 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:10:06 T:139987368511424 DEBUG: LIRC: Update - NEW at 190761:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:10:06 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:10:06 T:139987368511424 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
13:10:06 T:139987368511424 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
reviousWindow: Activate new
13:10:06 T:139987368511424 DEBUG: ------ Window Init (Settings.xml) ------
13:10:06 T:139985185400576 NOTICE: Thread JobWorker start, auto delete: true
13:10:06 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:10:07 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:10:08 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:10:08 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:10:08 T:139987368511424 DEBUG: LIRC: Update - NEW at 192750:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:10:08 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:10:08 T:139987368511424 DEBUG: Activating window ID: 10000
13:10:08 T:139987368511424 DEBUG: ------ Window Deinit (Settings.xml) ------
13:10:08 T:139987368511424 DEBUG: ------ Window Init (Home.xml) ------
13:10:09 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:10:16 T:139987368511424 DEBUG: LIRC: Update - NEW at 200344:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:10:16 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:10:16 T:139987368511424 DEBUG: Activating window ID: 10025
13:10:16 T:139987368511424 DEBUG: ------ Window Deinit (Home.xml) ------
13:10:16 T:139987368511424 DEBUG: ------ Window Init (MyVideoNav.xml) ------
13:10:16 T:139987368511424 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
13:10:16 T:139987368511424 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
13:10:16 T:139987368511424 DEBUG: Loading items: 3, directory: plugin://plugin.video.netflixbmc/ sort method: 0, ascending: false
13:10:16 T:139986925655808 NOTICE: Thread BackgroundLoader start, auto delete: false
13:10:16 T:139985185400576 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-x86_64-linux.so)
13:10:16 T:139985185400576 DEBUG: Loading: /usr/lib/kodi/system/ImageLib-x86_64-linux.so
13:10:16 T:139986925655808 DEBUG: Thread BackgroundLoader 139986925655808 terminating
13:10:16 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:10:16 T:139987368511424 DEBUG: ------ Window Init (Pointer.xml) ------
13:10:18 T:139987368511424 DEBUG: LIRC: Update - NEW at 202650:110 0 BTN_MOUSE /dev/input/event3 (BTN_MOUSE)
13:10:18 T:139987368511424 DEBUG: ProcessMouse: trying mouse action leftclick
13:10:18 T:139987368511424 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/?mode=main&thumb&type=movie&url)
13:10:18 T:139987368511424 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
13:10:18 T:139985185400576 DEBUG: StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','6','?mode=main&thumb&type=movie&url')
13:10:18 T:139985185400576 DEBUG: WaitOnScriptResult - waiting on the NetfliXBMC (id=18) plugin...
13:10:18 T:139986925655808 NOTICE: Thread LanguageInvoker start, auto delete: false
13:10:18 T:139986925655808 INFO: initializing python engine.
13:10:18 T:139986925655808 DEBUG: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): start processing
13:10:18 T:139986925655808 NOTICE: -->Python Interpreter Initialized<--
13:10:18 T:139986925655808 DEBUG: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): the source file to load is "/home/richard/.kodi/addons/plugin.video.netflixbmc/default.py"
13:10:18 T:139986925655808 DEBUG: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): setting the Python path to /home/richard/.kodi/addons/plugin.video.netflixbmc:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages/ubuntu-sso-client:/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode
13:10:18 T:139986925655808 DEBUG: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): entering source directory /home/richard/.kodi/addons/plugin.video.netflixbmc
13:10:18 T:139986925655808 DEBUG: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
13:10:18 T:139986925655808 DEBUG: LocalizeStrings: no strings.po file exist at /home/richard/.kodi/addons/plugin.video.netflixbmc/resources/language/English, fallback to strings.xml
13:10:18 T:139985185400576 DEBUG: WaitOnScriptResult- plugin returned successfully
13:10:18 T:139986925655808 INFO: CPythonInvoker(18, /home/richard/.kodi/addons/plugin.video.netflixbmc/default.py): script successfully run
13:10:18 T:139985160222464 NOTICE: Thread BackgroundLoader start, auto delete: false
13:10:18 T:139987368511424 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:10:18 T:139985160222464 DEBUG: Thread BackgroundLoader 139985160222464 terminating
13:10:18 T:139986925655808 INFO: Python script stopped
