Ok so the addon is working on my nix machine but not on my windows machine, All it does is go back to the Video Addons menu. Here is a snippet of the logs:
16:27:03 T:2396 DEBUG: ------ Window Init (MyVideoNav.xml) ------
16:27:03 T:2396 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
16:27:03 T:2396 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
16:27:03 T:2396 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
16:27:03 T:2396 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','1','')
16:27:03 T:2396 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=10) plugin...
16:27:03 T:3844 NOTICE: Thread LanguageInvoker start, auto delete: false
16:27:03 T:3844 INFO: initializing python engine.
16:27:03 T:3844 DEBUG: CPythonInvoker(10, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
16:27:03 T:3844 NOTICE: -->Python Interpreter Initialized<--
16:27:03 T:3844 DEBUG: CPythonInvoker(10, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
16:27:03 T:3844 DEBUG: CPythonInvoker(10, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\Kodie\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
16:27:03 T:3844 DEBUG: CPythonInvoker(10, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
16:27:03 T:3844 DEBUG: CPythonInvoker(10, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
16:27:03 T:3844 NOTICE: URL:
https://www.netflix.com/Login
16:27:04 T:3844 INFO: Python script stopped
16:27:04 T:3844 DEBUG: Thread LanguageInvoker 3844 terminating
16:27:04 T:2396 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
16:27:04 T:2396 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
16:27:04 T:2396 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
16:27:04 T:2396 DEBUG: CGUIMediaWindow::GetDirectory ()
16:27:04 T:2396 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
16:27:04 T:3948 NOTICE: Thread BackgroundLoader start, auto delete: false
16:27:04 T:3948 DEBUG: Thread BackgroundLoader 3948 terminating
16:27:08 T:2396 DEBUG: ------ Window Deinit (Pointer.xml) ------
16:27:11 T:2396 DEBUG: ------ Window Init (Pointer.xml) ------
16:27:15 T:2396 DEBUG: CApplication:
rocessMouse: trying mouse action leftclick
16:27:15 T:2396 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
16:27:15 T:2396 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
reviousWindow: Activate new
16:27:15 T:2396 DEBUG: ------ Window Init (Home.xml) ------
16:27:17 T:2396 DEBUG: CApplication:
16:27:17 T:2396 DEBUG: Activating window ID: 10025
16:27:18 T:2396 DEBUG: ------ Window Deinit (Home.xml) ------
16:27:18 T:2396 DEBUG: ------ Window Init (MyVideoNav.xml) ------
16:27:18 T:2396 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
16:27:18 T:2396 DEBUG: ParentPath = [plugin://plugin.video.netflixbmc/]
16:27:18 T:2396 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','2','')
16:27:18 T:2396 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=11) plugin...
16:27:18 T:3884 NOTICE: Thread LanguageInvoker start, auto delete: false
16:27:18 T:3884 INFO: initializing python engine.
16:27:18 T:3884 DEBUG: CPythonInvoker(11, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
16:27:18 T:3884 NOTICE: -->Python Interpreter Initialized<--
16:27:18 T:3884 DEBUG: CPythonInvoker(11, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
16:27:18 T:3884 DEBUG: CPythonInvoker(11, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\Kodie\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
16:27:18 T:3884 DEBUG: CPythonInvoker(11, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
16:27:18 T:3884 DEBUG: CPythonInvoker(11, C:\Users\Kodie\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
16:27:18 T:3884 NOTICE: URL:
16:27:18 T:3884 INFO: Python script stopped
16:27:18 T:3884 DEBUG: Thread LanguageInvoker 3884 terminating
16:27:18 T:2396 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
16:27:18 T:2396 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
16:27:18 T:2396 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
16:27:18 T:2396 DEBUG: CGUIMediaWindow::GetDirectory ()
16:27:18 T:3652 NOTICE: Thread BackgroundLoader start, auto delete: false
16:27:18 T:3652 DEBUG: Thread BackgroundLoader 3652 terminating
16:27:21 T:2396 DEBUG: CApplication:
16:27:21 T:2396 DEBUG: CGUIWindowManager:
16:27:22 T:2396 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
16:27:22 T:2396 DEBUG: CGUIWindowManager:
16:27:22 T:2396 DEBUG: ------ Window Init (Home.xml) ------
Any thoughts? :-)
