(2015-05-19, 14:40)Snicket Wrote: [ -> ] (2015-05-17, 11:15)ScotchToberFest Wrote: [ -> ]Hi, sorry I'm new here and apologize if this has already been brought up before, but I'm having an issue with my install where I go to play a video, chrome launches full screen and starts playing the video and the focus returns back to Kodi. The video continues to play in the background while the Kodi menu's is all I can see, and I have no easy way to switch to the background process using a remote. The only way I can really do it is by closing Kodi entirely and then the chrome video becomes the main window. Windows 8.1 and Kodi, can't remember the exact version right now.
Do you use Launcher4Kodi?
It forces the focus on Kodi but you can disable Kodi focus in Launcher4Kodi for certain Software (ex. Chrome).
Yes, I'm pretty sure I do use this. I'll check it out, thanks for the tip.
EDIT: Yep, that seemed to be the problem. I set it up to force focus only once with a delay and that seemed to do the trick. I set it up to disable focus if Chrome was running but that gave me some startup focus issues because of another instance of chrome running in the background. Thanks Snicket.
(2015-05-20, 14:21)ScotchToberFest Wrote: [ -> ] (2015-05-19, 14:40)Snicket Wrote: [ -> ] (2015-05-17, 11:15)ScotchToberFest Wrote: [ -> ]Hi, sorry I'm new here and apologize if this has already been brought up before, but I'm having an issue with my install where I go to play a video, chrome launches full screen and starts playing the video and the focus returns back to Kodi. The video continues to play in the background while the Kodi menu's is all I can see, and I have no easy way to switch to the background process using a remote. The only way I can really do it is by closing Kodi entirely and then the chrome video becomes the main window. Windows 8.1 and Kodi, can't remember the exact version right now.
I'm glad I could help you
So is there any way to do the following:
1. Return to KODI via phone app?
2. Control playback? Pick a new show in browser, etc. ?
It would be hugely beneficial to me to be able to specify the path to the custom browser.sh file.
The chrome plugin has this option.
The way things are now every time time plugin gets updated it overwrites the custom changes I have made and removes the execute flag.
I'd like to put the script in the user directory.
Anyone know what might cause this?
http://pastebin.com/7Hyi8xU9
Box is Win7 HP SP1 (fully updated) with Kodi 14.2. Can post the full debug log but the proceeding errors are basically the same thing as above.
I've tried turning off Advanced SSL, changing the SSL protocol, removing the "/Login" from default.py, removing myself from the Test Participation on Netflix - all to no avail.
Thanks for any help/
Hello, I'm running Kodi 14.2 Helix on Windows 8.1 and the NetfliXBMC add-on just gets stuck at Talking to Netflix - Starting login 25%
Can someone please help me getting this running. I've put in my username and password but just gets stuck.
Where is the log file to look at? Here is my log. Thx
07:43:38 T:3916 DEBUG: ------ Window Init (MyVideoNav.xml) ------
07:43:38 T:3916 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
07:43:38 T:3916 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
07:43:38 T:3916 DEBUG: ParentPath = [addons://sources/video/]
07:43:38 T:5064 NOTICE: Thread BackgroundLoader start, auto delete: false
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-poster.jpg
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-poster.png
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-banner.jpg
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-banner.png
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-fanart.jpg
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/fanart.jpg
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-fanart.png
07:43:38 T:5064 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/fanart.png
07:43:38 T:5064 DEBUG: Thread BackgroundLoader 5064 terminating
07:43:42 T:3916 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:43:42 T:3916 DEBUG: ------ Window Init (Pointer.xml) ------
07:43:43 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
07:43:44 T:3916 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
07:43:44 T:3916 DEBUG: ParentPath = [addons://sources/video/]
07:43:44 T:5640 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','1','')
07:43:44 T:5640 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=19) plugin...
07:43:44 T:6860 NOTICE: Thread LanguageInvoker start, auto delete: false
07:43:44 T:6860 INFO: initializing python engine.
07:43:44 T:6860 DEBUG: CPythonInvoker(19, C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): start processing
07:43:44 T:6860 NOTICE: -->Python Interpreter Initialized<--
07:43:44 T:6860 DEBUG: CPythonInvoker(19, C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py"
07:43:44 T:6860 DEBUG: CPythonInvoker(19, C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc;C:\Users\Chris\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
07:43:44 T:6860 DEBUG: CPythonInvoker(19, C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc
07:43:44 T:6860 DEBUG: CPythonInvoker(19, C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
07:43:44 T:3916 DEBUG: ------ Window Init (DialogBusy.xml) ------
07:43:45 T:6860 DEBUG: LocalizeStrings: no strings.po file exist at C:\Users\Chris\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\resources\language\English, fallback to strings.xml
07:43:45 T:6860 DEBUG: DialogProgress::StartModal called
07:43:45 T:6860 DEBUG: ------ Window Init (DialogProgress.xml) ------
07:43:45 T:6860 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
07:43:45 T:6860 NOTICE: URL: https://www.netflix.com/Login
07:43:46 T:6860 INFO: Python script stopped
07:43:46 T:6860 DEBUG: Thread LanguageInvoker 6860 terminating
07:43:46 T:5640 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
07:43:46 T:3916 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
07:43:46 T:3916 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
07:43:46 T:3916 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
07:43:46 T:3916 DEBUG: ParentPath = [addons://sources/]
07:43:46 T:6116 NOTICE: Thread BackgroundLoader start, auto delete: false
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-poster.jpg
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-poster.png
07:43:46 T:3916 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-banner.jpg
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-banner.png
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-fanart.jpg
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/fanart.jpg
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/?content_type=video-fanart.png
07:43:46 T:6116 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(script) in script://script.navi-x/fanart.png
07:43:46 T:6116 DEBUG: Thread BackgroundLoader 6116 terminating
07:43:48 T:3916 DEBUG: ------ Window Deinit (Pointer.xml) ------
07:43:51 T:3916 DEBUG: ------ Window Init (Pointer.xml) ------
07:43:52 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
07:44:03 T:3916 DEBUG: Previous line repeats 4 times.
07:44:03 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action doubleclick
07:44:03 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
07:44:04 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
07:44:04 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action doubleclick
07:44:05 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action doubleclick
07:44:05 T:3916 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
07:44:16 T:3916 DEBUG: CWinEventsWin32::WndProcWindow is active
07:44:16 T:5640 DEBUG: Thread JobWorker 5640 terminating (autodelete)
07:44:17 T:3916 DEBUG: CJoystick::Initialize : No Joystick found
07:44:17 T:3916 DEBUG: CWinEventsWin32::WndProcWindow is active
07:44:22 T:3916 DEBUG: Previous line repeats 1 times.
Full log to pastebin, not inline. Please remove the inline partial log.
(2015-05-21, 21:26)nickr Wrote: [ -> ]Full log to pastebin, not inline. Please remove the inline partial log.
Sorry, not sure what you mean.
(2015-05-22, 13:08)garydebergerac Wrote: [ -> ]Hi, I am getting a script failed error on Kodibuntu (just updated everything to latest), here's my log http://paste.ubuntu.com/11282847/
From your log:
plugin.video.netflixbmc-1.3.4
also the log is from a very old version of netflixbmc
Check your version it should be 1.3.21
(2015-05-22, 11:03)TICO Wrote: [ -> ]My pastebin for the SSL 'violation of protocol':
Oh and BTW, I don't go through any proxy.
I have no explanation for why that error is occurring. Can you logon the netflix with a browser on that computer?
(2015-05-22, 17:36)insertnamehere Wrote: [ -> ] (2015-05-22, 11:03)TICO Wrote: [ -> ]My pastebin for the SSL 'violation of protocol':
Good question! And it revealed my problem with an UnblockUs email confirmation page when trying to get to netflix.com. Oops! It's working now that I've fixed that, thanks!
So I recently moved the HTPC off of wifi onto ethernet, and totally forgot to check for adapter's DNS settings, which were the unblockus DNS servers from when I tested something a while ago. I always knew those nasty DNS hacks would come back to bite
I've got everything set up properly (I think...) and I'm getting this error after launching a Netflix video. This appears in Netflix's window in Chrome, not in Kodi.
"We cannot find all the required components to play Netflix on this device. Please visit chrome://components, locate the WidevineCdm component, and click the "Check for update" button."
I've done as it's asked and the component is already installed and up to date. Also if I just launch Chrome directly I can view Netflix just fine in it. It only throws this error if Chrome is launched from Kodi. Any ideas?
I'm also getting this "stuck at 25%" inside KODI "TALKING TO NETFLIX" "STARTING KODI".
I completely removed NETFLIXBMC and all user data from it, reinstalled, same problem.
EDIT: It's doing it on multiple machines - problem started a couple of days ago.
