(2015-01-20, 16:23)desmoloch Wrote: [ -> ] (2015-01-20, 08:25)corona Wrote: [ -> ]What OS are you running on?
Android (firetv)
As I tell everyone else like this,
Quote:As per the first post, this plugin only works on mac/windows/linux. Android will likely never be supported, because you can't watch netflix in chrome.
(2015-01-20, 16:53)Jamriman Wrote: [ -> ]kodi on Prometheus, nothing but script failures...
Please post a kodi.log of the errors, can't help much otherwise.
Some more information about your platform, os would be useful, although I'm guessing you're referring to
http://kodinow.com/ (I've never heard of it before)
(2015-01-20, 22:03)planetmarshall Wrote: [ -> ]I believe I'm having the same issue as jbourke, log attached here
http://pastebin.com/ZC5uxA2q
I can log in ok, but all the folder contents are empty. I'm a reasonably experienced python dev so if you can point me in the right direction I can submit a patch for the issue.
NetfliXBMC v 1.3.11
Kodi (14.0 Git:ad747d9)
Ubuntu 14.04.1 LTS, kernel: Linux x86 64-bit version 3.13.0-29-generic
Cheers,
Andrew.
That last line in your log is a normal warning, I had to disable cert checking a while back as it was failing with some of the redirects in place (ie I'm requesting
www.netflix.com and it's replying from login.netflix.com)
I'm not sure why things are coming up blank sorry.
Is this a new install, or was it working previously. Try a reset of cache from the settings page perhaps?
Also try turning on debug in netflix settings, then the log should print out all the url's accessed. They can then be tried directly in a browser to hopefully show the problem.
NetfliXBMC v 1.3.11
Cheers,
Andrew.
