2014-12-17, 07:26
Ubuntu 14.04 Kodi 14.0 “Helix” – RC 3 probably effects other versions and distros I have seen similar.
Simple fix:
gksudo nautilus
/usr/share/applications
OR!! Just go 'computer' and search for 'Kodi' and on the icon right click>open item location << that is the quickest way
then
Copy and paste the Kodi .desktop Icon into a folder named Kodi Original Launcher and then copy that folder and rename the folder Kodi Edited Launcher, saved some where SAFE encase you mess things up and aren't completely savi with .launcher files. (or know how to use or have installed the Gnome Create Launcher APP, if you don't its worth learning how to create your OWN custom launchers).
LEAVE gksudo nautilus /usr/share/applications OPEN and work between the 2. Easy.
So, now open gedit>open>kodi.desktop FROM THE FOLDER NAMED Kodi Edited Launcher <<<
and then replace:
[Desktop Action Fullscreen]
Name=Open in fullscreen
Exec=kodi -fs << EDIT THIS LINE!!**
OnlyShowIn=Unity;
Exec=xbmc -fs <<TO THIS LINE!!*
OnlyShowIn=Unity;
Save file, copy and paste to gksudo nautilus /usr/share/applications folder still open, replace. Wallah, will always open up full screen with no bar at the top.
Like other APPS on Ubuntu or derivatives IF you edit a launcher and then the APP gets an update and installs via PPA or you download and install it the launcher will be OVER written with the new and will NOT work, so you can just edit them again.
That's my work around.
Simple fix:
gksudo nautilus
then
and then replace:
OnlyShowIn=Unity;
OnlyShowIn=Unity;
