Update
I turned on verbose CURL and FFmpeg logging, and got this in the logs:
06:52:57 T:140007098058752 NOTICE: DVDPlayer: Opening: http://ak.live.cntv.cn/i/cctv13_1@101095/master.m3u8?b=300-500&AUTH=ip%3D1.2.3.4%7Est%3D1418971672%7Eexp%3D1419058072%7Eacl%3D%2F*%7Ehmac%3D8968f364bd16cf3add65408933843e03d6325f74ba12f25e51a72790e9552b4f
06:52:57 T:140007098058752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
06:52:57 T:140007098058752 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
06:52:57 T:140007098058752 DEBUG: LinuxRendererGL: Cleaning up GL resources
06:52:57 T:140007098058752 DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
06:52:57 T:140006050264832 NOTICE: Thread DVDPlayer start, auto delete: false
06:52:57 T:140006050264832 NOTICE: Creating InputStream
06:52:57 T:140006050264832 DEBUG: CFileCache::Open - opening <i/cctv13_1@101095/master.m3u8> using cache
06:52:57 T:140006050264832 DEBUG: CurlFile::Open(0x7f55ac0a7fa0) http://ak.live.cntv.cn/i/cctv13_1@101095/master.m3u8?b=300-500&AUTH=ip%3D1.2.3.4%7Est%3D1418971672%7Eexp%3D1419058072%7Eacl%3D%2F*%7Ehmac%3D8968f364bd16cf3add65408933843e03d6325f74ba12f25e51a72790e9552b4f
06:52:57 T:140006050264832 DEBUG: Curl::Debug - TEXT: Hostname was NOT found in DNS cache
06:52:57 T:140006050264832 DEBUG: Curl::Debug - TEXT: Trying 202.7.187.26...
06:52:57 T:140006050264832 DEBUG: Curl::Debug - TEXT: Connected to ak.live.cntv.cn (202.7.187.26) port 80 (#0)
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: GET /i/cctv13_1@101095/master.m3u8?b=300-500&AUTH=ip%3D1.2.3.4%7Est%3D1418971672%7Eexp%3D1419058072%7Eacl%3D%2F*%7Ehmac%3D8968f364bd16cf3add65408933843e03d6325f74ba12f25e51a72790e9552b4f HTTP/1.1
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: Range: bytes=0-
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: User-Agent: Kodi/14.0-RC3 (X11; Linux x86_64) Arch Linux/rolling App_Bitness/64 Version/14.0-RC3-Git:Unknown
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: Host: ak.live.cntv.cn
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: Accept: */*
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: Cookie: _alid_=ucdGQYkNdh9Iu0288Cbn/w==
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_OUT: Accept-Charset: UTF-8,*;q=0.8
06:52:57 T:140007098058752 DEBUG: ------ Window Init (DialogBusy.xml) ------
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: HTTP/1.1 200 OK
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Server: AkamaiGHost
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Content-Length: 639
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Content-Type: application/vnd.apple.mpegurl
06:52:57 T:140006050264832 DEBUG: Curl::Debug - TEXT: Replaced cookie _alid_="ucdGQYkNdh9Iu0288Cbn/w==" for domain ak.live.cntv.cn, path /i/cctv13_1@101095/, expire 0
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Set-Cookie: _alid_=ucdGQYkNdh9Iu0288Cbn/w==; path=/i/cctv13_1@101095/; domain=ak.live.cntv.cn
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Mime-Version: 1.0
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Access-Control-Allow-Origin: *
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Expires: Fri, 19 Dec 2014 06:52:57 GMT
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Cache-Control: max-age=0, no-cache, no-store
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Pragma: no-cache
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Date: Fri, 19 Dec 2014 06:52:57 GMT
06:52:57 T:140006050264832 DEBUG: Curl::Debug - HEADER_IN: Connection: keep-alive
06:52:57 T:140005430757120 NOTICE: Thread FileCache start, auto delete: false
06:52:57 T:140005430757120 DEBUG: Curl::Debug - TEXT: Connection #0 to host ak.live.cntv.cn left intact
06:52:57 T:140005430757120 INFO: CFileCache::Process - Hit eof.
06:52:57 T:140005430757120 DEBUG: Thread FileCache 140005430757120 terminating
06:52:57 T:140006050264832 INFO: CDVDInputStreamFFmpeg: Auto-selecting http://ak.live.cntv.cn/i/cctv13_1@101095/index_500_av-p.m3u8?AUTH= based on configured bandwidth.
06:52:57 T:140006050264832 NOTICE: Creating Demuxer
06:52:57 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
06:52:57 T:140007098058752 DEBUG: Previous line repeats 1 times.
06:52:57 T:140007098058752 DEBUG: ------ Window Init (Pointer.xml) ------
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] request: GET /i/cctv13_1@101095/index_500_av-p.m3u8?AUTH= HTTP/1.1
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] User-Agent: Kodi/14.0-RC3 (X11; Linux x86_64) Arch Linux/rolling App_Bitness/64 Version/14.0-RC3-Git:Unknown
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Accept: */*
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Range: bytes=0-
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Connection: close
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Host: ak.live.cntv.cn
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Cookie: _alid_=ucdGQYkNdh9Iu0288Cbn/w==
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] Icy-MetaData: 1
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] header='HTTP/1.1 302 Moved Temporarily'
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] http_code=302
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] header='Server: AkamaiGHost'
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] header='Content-Length: 0'
06:52:58 T:140006050264832 DEBUG: ffmpeg[7F55B2E47700]: [http] header='Location: http://v.cctv.com/flash/live_back/copyright.mp4'
As the log shows, Kodi correctly downloads the M3U8 file:
The contents of this file are:
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=458000,RESOLUTION=720x576,CODECS="avc1.77.30, mp4a.40.2"
http://ak.live.cntv.cn/i/cctv13_1@101095/index_500_av-p.m3u8?AUTH=ip%3D1.2.3.4%7Est%3D1418972109%7Eexp%3D1419058509%7Eacl%3D%2F*%7Ehmac%3D21640c72456e49c34dc433fcf47bf2808fa1f86b8ee582c49764f969e7514410&sd=10&b=300-500&rebase=on
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=46000,CODECS="mp4a.40.2"
http://ak.live.cntv.cn/i/cctv13_1@101095/index_500_a-p.m3u8?AUTH=ip%3D1.2.3.4%7Est%3D1418972109%7Eexp%3D1419058509%7Eacl%3D%2F*%7Ehmac%3D21640c72456e49c34dc433fcf47bf2808fa1f86b8ee582c49764f969e7514410&sd=10&b=300-500&rebase=on
But after dowloading this M3U8 file, it randomly decides to drop the contents of the AUTH parameter:
url = url.replace("master.m3u8?b=100-300&", "index_500_av-p.m3u8?")
Changing my code to manually bypass the master.m3u8 file, as above, works, but I would really like a better solution to this problem.
