I have an plugin that do not work on opeelec , with other plataformas works fine but with linux (openelec and crystalubutu) i can not make it run where i can get help tp make it work on that plataform?
my log
the plugin is xbtv
thanks a lot
You've posted this in the Raspberry Pi support forum, yet your OpenELEC build is Intel 32-bit. Maybe a moderator can move this somewhere more appropriate?
18:49:43 T:2949958464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'URLError' object has no attribute 'code'
File "/storage/.xbmc/addons/plugin.video.XbTV/default.py", line 1278, in <module>
OoO ( oo0Ooo0 )
File "/storage/.xbmc/addons/plugin.video.XbTV/default.py", line 696, in OoO
print Ii1I1Ii . code
AttributeError: 'URLError' object has no attribute 'code'
18:50:23 T:2949958464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error no host given>
File "/storage/.xbmc/addons/plugin.video.XbTV/default.py", line 1307, in <module>
O0oOOoooOO0O ( )
File "/storage/.xbmc/addons/plugin.video.XbTV/default.py", line 742, in O0oOOoooOO0O
II = II11IiIi11 . open ( oo0Ooo0 )
File "/home/stephan/projects/openelec-4.2/build.OpenELEC-ATV.i386-4.2.1/Python-2.7.3/.install_pkg/usr/lib/python2.7/urllib2.py", line 398, in open
File "/home/stephan/projects/openelec-4.2/build.OpenELEC-ATV.i386-4.2.1/Python-2.7.3/.install_pkg/usr/lib/python2.7/urllib2.py", line 1106, in do_request_
URLError: <urlopen error no host given>
Contact the author of the addon.
