2015-07-03, 14:30
2015-07-04, 23:19
For those looking to build on master, I forked sparklyballs' docker repo and modified the 5071.patch to apply to the latest kodi 16 master (Line 282 needed modification due to a recent change in GUIDialog.cpp).
Haven't built for docker but the 5071.patch applies to master and I built headless successfully to run on my server with videodb version 94.
https://github.com/acandido/docker-conta...odi-16/src
2015-07-06, 15:09
I was more thinking kodi 15, as master was then but nice work
2015-07-07, 05:09
(2015-07-06, 15:09)marantz Wrote: [ -> ]I was more thinking kodi 15, as master was then but nice work
Sparklyballs' repo has the patch that will work on 15:
https://github.com/sparklyballs/docker-c...i-isengard
2015-07-08, 22:59
(2015-07-07, 05:09)acandido Wrote: [ -> ](2015-07-06, 15:09)marantz Wrote: [ -> ]I was more thinking kodi 15, as master was then but nice work
that patch doesn't seem to work, the patch fails on /xbmc/guilib/GUIDialog.cpp
So i replaced code manually but then my build failed...
Am i doing this right? i build helix fine...
git clone https://github.com/xbmc/xbmc.git -b Isengard --depth=1 kodi
cd kodi
git apply --check 5071.patch
manually fix problem as mentioned above, remove that bit from the patch file
git apply 5071.patch
./bootstrap
./configure --prefix=/opt/kodi-server-isengard
make
make[1]: Leaving directory `/root/isengard/lib/libdvd'
CPP xbmc/cores/dvdplayer/DVDAudio.o
CPP xbmc/cores/dvdplayer/DVDClock.o
CPP xbmc/cores/dvdplayer/DVDDemuxSPU.o
CPP xbmc/cores/dvdplayer/DVDFileInfo.o
CPP xbmc/cores/dvdplayer/DVDMessage.o
CPP xbmc/cores/dvdplayer/DVDMessageQueue.o
CPP xbmc/cores/dvdplayer/DVDOverlayContainer.o
CPP xbmc/cores/dvdplayer/DVDOverlayRenderer.o
CPP xbmc/cores/dvdplayer/DVDPlayer.o
In file included from DVDPlayer.cpp:22:0:
DVDPlayer.h:157:23: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:157:23: error: ISO C++ forbids in-class initialisation of non-const static member ‘type’
DVDPlayer.h:158:29: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:158:29: error: ISO C++ forbids in-class initialisation of non-const static member ‘type_index’
DVDPlayer.h:163:46: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:163:46: error: ISO C++ forbids in-class initialisation of non-const static member ‘flags’
DVDPlayer.h:164:25: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:164:25: error: ISO C++ forbids in-class initialisation of non-const static member ‘source’
DVDPlayer.h:165:21: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:165:21: error: ISO C++ forbids in-class initialisation of non-const static member ‘id’
DVDPlayer.h:167:27: sorry, unimplemented: non-static data member initialisers
DVDPlayer.h:167:27: error: ISO C++ forbids in-class initialisation of non-const static member ‘channels’
/root/isengard/xbmc/guilib/GraphicContext.h:296:1: warning: ‘g_graphicsContext’ defined but not used [-Wunused-variable]
make[1]: *** [DVDPlayer.o] Error 1
make: *** [xbmc/cores/dvdplayer/DVDPlayer.a] Error 2
UPDATE: trying "git reset --hard 9ff25f8" now, which commit should it be on? with this one i dont get conflicts when patching.
UPDATE2: same error
2015-07-09, 09:24
Use a C++11 compiler ... your issue is not related to the patch ... you cannot even build normal master.
2015-07-09, 09:29
yep, same reason ubuntu precise PPA builds are broken, gcc is too old. You need at least gcc 4.7, better 4.8
2015-07-09, 10:43
(2015-07-09, 09:29)wsnipex Wrote: [ -> ]yep, same reason ubuntu precise PPA builds are broken, gcc is too old. You need at least gcc 4.7, better 4.8
OK Thanks, I will try it with new version of gcc, i foolishly assumed that since i could build helix i could build isengard (seems not, which makes sense) also it was late so thats my excuse
I'm sure it will work once it's updated.
Thanks again.
Update : Forgot i have remote access, trying it now, seems to be working so far, thanks so much and i'm sure that was a silly mistake but thats how people learn
2015-07-09, 15:18
Ok so i tried it again...
git clone...
git apply....
./bootstrap
make -j2
make install
/opt/kodi-server/lib/kodi/kodi.bin --headless -p
Unable to find path to Kodi data files!
git clone...
git apply....
./bootstrap
make -j2
make install
2015-07-09, 19:40
git clean -xfd, then try again
2015-07-09, 20:21
can you provide an updated patch for 5071.patch.
cheers
cheers
2015-07-09, 22:52
(2015-07-09, 19:40)wsnipex Wrote: [ -> ]git clean -xfd, then try again
thanks that worked! all up and running on kodi isengard RC1
2015-07-09, 22:53
(2015-07-09, 20:21)xxxnelly Wrote: [ -> ]can you provide an updated patch for 5071.patch.
cheers
just revert to the commit for rc1 - "git reset --hard 9ff25f8" or manually patch the files, or create a new patch yourself, it's mostly the same just a few changes in 1 file.
2015-07-12, 22:41
I believe this is a working patch for RC2 atleast it worked for me...
https://gist.github.com/Fma965/b01099fd8...atch-patch
wget https://gist.githubusercontent.com/Fma96...atch.patch
cd kodi
git reset --hard 0aa930b (just to make sure is same commit)
git apply --check RC2Patch.patch
git apply RC2Patch.patch
./bootstrap
make -j2
make install
2015-07-16, 00:11
Hi to all,
first i have to say, i'm a really noob in compiling programs
but i have to ask you: has anyone really running Kodi (Isengard) Headless running
I tried all your hints without success
With Helix the server is running with web-server, so i can see my media, but i can not stream them to my phone (Yatse as client)
When i try to stream a mp3 the server crashes.
With Isengard i get the web-server not started.
So, i wish to run Isengard (Headless) on my Ubuntu Server (15.04 / 64 Bit) to update the MySQL-Server and stream my media to my mobile device (Android)
Is it possible to give me a Noob-Ready step by step or better already compiled zip/deb?
Thanks a lot for your help and comprehension
IncMrG
IncMrG
