2017-12-16, 23:01
if you enter/exit/enter tv or movies does it not update? It should if its using the same shared mysql database as the kodi headless..
(2018-03-06, 09:02)celedhrim Wrote: [ -> ]I have build it , but not test ( I wait libreelec update)/opt/kodi-server-18.0a1/bin$ ./kodi --headless
https://github.com/Celedhrim/docker-kodi.../tree/leia
https://hub.docker.com/r/celedhrim/kodi-server/tags/
Have fun testing
Quote:CMD ["/opt/kodi-server/lib/kodi/kodi.bin","--headless","--no-test","--nolirc","-p"]
Quote:CMD ["/opt/kodi-server/lib64/kodi/kodi-x11","--headless","--no-test","--nolirc","-p"]
json:
10:35:55.678 T:139764771383296 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:35:55.678 T:139764771383296 NOTICE: -----------------------------------------------------------------------
10:35:55.678 T:139764771383296 NOTICE: Starting Kodi (18.0-ALPHA1 Git:20180304-89a53e4-dirty). Platform: Linux x86 64-bit
10:35:55.678 T:139764771383296 NOTICE: Using Release Kodi x64 build
10:35:55.678 T:139764771383296 NOTICE: Kodi compiled Mar 6 2018 by GCC 5.4.0 for Linux x86 64-bit version 4.4.98 (263266)
10:35:55.678 T:139764771383296 NOTICE: Running on Ubuntu 16.04.4 LTS, kernel: Linux x86 64-bit version 4.4.0-109-generic
10:35:55.678 T:139764771383296 NOTICE: FFmpeg version/source: 3.4.1-Kodi
10:35:55.678 T:139764771383296 NOTICE: Host CPU: Intel® Xeon® CPU E5620 @ 2.40GHz, 16 cores available
10:35:55.678 T:139764771383296 NOTICE: special://xbmc/ is mapped to: /opt/kodi-server-18.0a1/share/kodi/
10:35:55.678 T:139764771383296 NOTICE: special://xbmcbin/ is mapped to: /opt/kodi-server-18.0a1/lib/kodi
10:35:55.678 T:139764771383296 NOTICE: special://xbmcbinaddons/ is mapped to: /opt/kodi-server-18.0a1/lib/kodi/addons
10:35:55.678 T:139764771383296 NOTICE: special://masterprofile/ is mapped to: /opt/kodi-server-18.0a1/share/kodi/portable_data/userdata
10:35:55.678 T:139764771383296 NOTICE: special://envhome/ is mapped to: /home/bleh
10:35:55.678 T:139764771383296 NOTICE: special://home/ is mapped to: /opt/kodi-server-18.0a1/share/kodi/portable_data
10:35:55.678 T:139764771383296 NOTICE: special://temp/ is mapped to: /opt/kodi-server-18.0a1/share/kodi/portable_data/temp
10:35:55.678 T:139764771383296 NOTICE: special://logpath/ is mapped to: /opt/kodi-server-18.0a1/share/kodi/portable_data/temp
10:35:55.678 T:139764771383296 NOTICE: The executable running is: /opt/kodi-server-18.0a1/lib/kodi/kodi-x11
10:35:55.678 T:139764771383296 NOTICE: Local hostname: media
10:35:55.678 T:139764771383296 NOTICE: Log File is located: /opt/kodi-server-18.0a1/share/kodi/portable_data/temp//kodi.log
10:35:56.726 T:139764771383296 NOTICE: load settings...
10:35:56.732 T:139764771383296 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
10:35:56.735 T:139764771383296 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
10:35:56.736 T:139764771383296 DEBUG: SECTION:LoadDLL(libbluray.so.2)
10:35:56.736 T:139764771383296 DEBUG: Loading: libbluray.so.2
10:35:56.743 T:139764771383296 DEBUG: CSkinSettings: no <skinsettings> tag found
10:35:56.743 T:139764771383296 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:35:56.743 T:139764771383296 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:35:56.743 T:139764771383296 NOTICE: Default Video Player: VideoPlayer
10:35:56.743 T:139764771383296 NOTICE: Default Audio Player: paplayer
10:35:56.743 T:139764771383296 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:35:56.743 T:139764771383296 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:35:56.747 T:139764771383296 NOTICE: Running database version Addons27
10:35:56.753 T:139764771383296 NOTICE: ADDON: xbmc.json v9.1.1 installed
10:35:56.753 T:139764771383296 NOTICE: ADDON: metadata.common.fanart.tv v3.1.5 installed
10:35:56.753 T:139764771383296 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
10:35:56.753 T:139764771383296 NOTICE: ADDON: repository.xbmc.org v3.0.5 installed
10:35:56.753 T:139764771383296 NOTICE: ADDON: webinterface.default v2.4.4 installed
10:35:56.753 T:139764771383296 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.main v1.0.12 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: game.controller.default v1.0.5 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.39 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.themoviedb.org v5.1.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: service.xbmc.versioncheck v0.3.26 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.resource v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: script.module.pil v1.1.7 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.gui v5.13.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.core v0.1.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: skin.estouchy v2.0.12 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.album.universal v2.7.3 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.adsp v0.2.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.game v1.0.36 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.pvr v5.8.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.common.allmusic.com v3.1.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.common.musicbrainz.org v2.1.2 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.tvdb.com v3.0.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.local v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.6 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.common.themoviedb.org v2.17.6 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.common.theaudiodb.com v1.9.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.artists.universal v4.1.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: metadata.common.imdb.com v2.9.3 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.python v2.25.0 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: xbmc.addon v17.9.701 installed
10:35:56.754 T:139764771383296 NOTICE: ADDON: skin.estuary v2.0.7 installed
10:35:56.764 T:139764293424896 NOTICE: No Devices found - retry: 4
10:35:58.265 T:139764293424896 NOTICE: No Devices found - retry: 3
10:35:59.765 T:139764293424896 NOTICE: No Devices found - retry: 2
10:36:01.265 T:139764293424896 NOTICE: No Devices found - retry: 1
10:36:02.765 T:139764293424896 NOTICE: Found 0 Lists of Devices
10:36:02.765 T:139764285032192 ERROR: CActiveAESink::OpenSink - no sink was returned
10:36:02.765 T:139764293424896 ERROR: ActiveAE::InitSink - returned error
10:36:02.792 T:139764069189376 NOTICE: Running database version Addons27
10:36:02.792 T:139764069189376 NOTICE: Running database version ViewModes6
10:36:02.793 T:139764069189376 NOTICE: Running database version Textures13
10:36:02.794 T:139764069189376 NOTICE: Running database version MyMusic70
10:36:02.796 T:139764069189376 NOTICE: Running database version MyVideos109
10:36:02.797 T:139764069189376 NOTICE: Running database version TV32
10:36:02.797 T:139764069189376 NOTICE: Running database version Epg11
xml:
diff --git a/xbmc/Application.cpp b/xbmc/Application.cpp
index 8fe1ed5..dc2b59c 100644
--- a/xbmc/Application.cpp
+++ b/xbmc/Application.cpp
@@ -258,6 +258,7 @@ CApplication::CApplication(void)
, m_lastRenderTime(0)
, m_skipGuiRender(false)
, m_bStandalone(false)
+ , m_headless(false)
, m_bEnableLegacyRes(false)
, m_bTestMode(false)
, m_bSystemScreenSaverEnable(false)
@@ -605,7 +606,7 @@ bool CApplication::Create(const CAppParamParser ¶ms)
return false;
// start the AudioEngine
- if(!m_ServiceManager->StartAudioEngine())
+ if(!IsHeadless() && !m_ServiceManager->StartAudioEngine())
CLog::Log(LOGFATAL, "CApplication::Create: Failed to start the AudioEngine");
return false;
@@ -707,7 +708,8 @@ bool CApplication::CreateGUI()
if (sav_res)
CDisplaySettings::GetInstance().SetCurrentResolution(RES_DESKTOP, true);
- CServiceBroker::GetRenderSystem().ShowSplash("");
+ if (!IsHeadless())
+ CServiceBroker::GetRenderSystem().ShowSplash("");
// The key mappings may already have been loaded by a peripheral
CLog::Log(LOGINFO, "load keymapping");
@@ -1054,7 +1056,7 @@ bool CApplication::Initialize()
int iDots = 1;
while (!event.WaitMSec(1000))
- if (databaseManager.IsUpgrading())
+ if (databaseManager.IsUpgrading() && !IsHeadless())
CServiceBroker::GetRenderSystem().ShowSplash(std:tring(iDots, ' ') + localizedStr + std:tring(iDots, '.'));
if (iDots == 3)
@@ -1062,7 +1064,8 @@ bool CApplication::Initialize()
else
++iDots;
StartServices();
@@ -1090,14 +1093,15 @@ bool CApplication::Initialize()
iDots = 1;
- if (isMigratingAddons)
+ if (isMigratingAddons && !IsHeadless())
if (iDots == 3)
iDots = 1;
else
++iDots;
m_incompatibleAddons = incompatibleAddons;
m_confirmSkinChange = true;
@@ -1823,7 +1827,7 @@ bool CApplication::LoadCustomWindows()
void CApplication::Render()
// do not render if we are stopped or in background
- if (m_bStop)
+ if (m_bStop || IsHeadless())
return;
bool hasRendered = false;
@@ -2713,11 +2717,13 @@ bool CApplication::Cleanup()
m_globalScreensaverInhibitor.Release();
m_screensaverInhibitor.Release();
- CServiceBroker::GetRenderSystem().DestroyRenderSystem();
- CServiceBroker::GetWinSystem().DestroyWindow();
- CServiceBroker::GetWinSystem().DestroyWindowSystem();
- g_windowManager.DestroyWindows();
+ if (!IsHeadless()) {
+ CServiceBroker::GetRenderSystem().DestroyRenderSystem();
+ CServiceBroker::GetWinSystem().DestroyWindow();
+ CServiceBroker::GetWinSystem().DestroyWindowSystem();
+ g_windowManager.DestroyWindows();
CLog::Log(LOGNOTICE, "unload sections");
@@ -4004,10 +4010,13 @@ bool CApplication::OnMessage(CGUIMessage& message)
if (!m_appPlayer.IsPlayingVideo())
- if(g_windowManager.GetActiveWindow() == WINDOW_FULLSCREEN_VIDEO ||
- g_windowManager.GetActiveWindow() == WINDOW_FULLSCREEN_GAME)
- g_windowManager.PreviousWindow();
+ if(g_windowManager.GetActiveWindow() == WINDOW_FULLSCREEN_VIDEO ||
+ g_windowManager.GetActiveWindow() == WINDOW_FULLSCREEN_GAME)
+ g_windowManager.PreviousWindow();
else
