2018-09-24, 09:38
2018-09-24, 14:59
Yeah...SMBv1 is enabled on my Win10 machine...
It's weird that only the docker container isn't able to access it. I shared a folder on my kid's Win10 PC for testing, can access it from anywhere except from the container as well, so it has to do with Win10.
I'll dig some more, thanks!
2018-10-05, 15:29
Hi All,
I've been using the patches for years to run a headless kodi on a server for updates.
After compiling the kodi-gbm version I'm trying to run the headless option but I can't find how to get it to run.
When started normally it eventually seg faults with:
ERROR: Unable to create GUI. Exiting
I've been able to run it using Ctrl-Alt-F<num> and run it without any display, but it takes over all displays and I can't get back to my normal windowed environment.
Any tips would be great as I'm trying to update the suite of kodi setups I'm using but the server is the critical link before any upgrades.
Thanks,
B.
Thanks,
B.
2018-10-05, 16:25
No option needed.
You need to make sure no X is running though.
You can do it like this:
sudo systemctl isolate multi-user.target
2018-10-05, 23:36
Does that basically take over all displays?
I'm looking to have it essentially be headless, whilst still being able to use the server for other tasks.
Thanks and Regards,
B.
Thanks and Regards,
B.
2018-10-06, 09:21
yes, gbm takes over the display. You cannot run on or in parallel to X11/Wayland
2018-10-09, 04:57
I still haven't been able to get GDM to work on my system. My user is in input, video, audio groups. My motherboard has built-in video that is an ASUS video card (not INTEL or NVIDIA, which I suspect could be my issue)
I ensured X wasn't running, multi-user, then did:
/opt/kodi-server-18.0b3/bin/kodi --no-test --nolirc -p
22:52:45.194 T:140165320243200 DEBUG: Selected UDev as storage provider
22:52:45.195 T:140165320243200 INFO: RetroPlayer[PROCESS]: Registering process control for GBM
22:52:45.195 T:140165320243200 INFO: RetroPlayer[RENDER]: Registering renderer factory for GBM
22:52:45.195 T:140165320243200 INFO: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
22:52:46.183 T:140164810602240 WARNING: CActiveAE::StateMachine - signal: 22 from port: timer not handled for state: 1
22:52:59.493 T:140165320243200 WARNING: Previous line repeats 13 times.
22:52:59.493 T:140165320243200 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize Atomic DRM
22:53:00.185 T:140164810602240 WARNING: CActiveAE::StateMachine - signal: 22 from port: timer not handled for state: 1
22:53:13.851 T:140165320243200 WARNING: Previous line repeats 13 times.
22:53:13.851 T:140165320243200 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize Legacy DRM
22:53:14.187 T:140164810602240 WARNING: CActiveAE::StateMachine - signal: 22 from port: timer not handled for state: 1
22:53:28.163 T:140165320243200 WARNING: Previous line repeats 13 times.
22:53:28.163 T:140165320243200 ERROR: CWinSystemGbm::InitWindowSystem - failed to initialize off screen DRM
22:53:28.163 T:140165320243200 FATAL: CApplication::Create: Unable to init windowing system
2018-10-26, 14:50
after upgrading with ubuntu ppa on ubuntu 18 to beta4 I get
ERROR: /dev/pts/8 is not a vt
2018-10-26, 15:22
Starting kodi-gbm over ssh is currently not working.
2018-10-26, 16:45
See https://forum.kodi.tv/showthread.php?tid...pid2785722
for needed systems service changes to start gbm
2018-10-27, 15:21
thanks! works again now.
2018-11-05, 12:04
After tonights upgrade to beta5 it broke again.
here is log http://paste.ubuntu.com/p/6qWffDHRhY/
Im using the startup script provided two posts earlier in this thread.
thanks for any help
thanks for any help
2018-11-13, 10:59
i noticed there are some gbm patches after last beta, is it worth trying to build from source?
2018-11-13, 21:24
(2018-11-13, 10:59)marantz Wrote: [ -> ]i noticed there are some gbm patches after last beta, is it worth trying to build from source?https://github.com/xbmc/xbmc/pull/14821 should make it work again.
You can wait for RC or build from source.
2018-11-22, 08:39
works again now with rc1, thanks!
