Full Version: Skin Kodi dependencies not met
Hey guys, need your help again.
After installling xbmcbuntu (gotham) to my htpc, I installed all outstanding updates.
This includes XBMC Kodi:
[email protected]:~# dpkg -l|grep -i kodi
ii  kodi                                 2:14.0~git20141223.1015-final-0trusty all          Kodi Media Center (arch-independent data package)
ii  kodi-bin                             2:14.0~git20141223.1015-final-0trusty amd64        Kodi Media Center (binary data package)
After fixing lightdm autologin, everything is working so far.
Now I wanted to install Aeon Nox. When I try to, I get the following error message:
I turned on the debug log, which says:
22:05:52 T:139767225046976   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
22:05:52 T:139767225046976   DEBUG: ------ Window Init (DialogAddonInfo.xml) ------
22:05:53 T:139766255400704   DEBUG: webserver: request received for /jsonrpc
22:05:56 T:139767225046976   DEBUG: Previous line repeats 2 times.
22:05:56 T:139767225046976   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
22:05:56 T:139767225046976   DEBUG: Addon skin.aeon.nox.5 requires xbmc.gui version 5.0.0 which is not available
22:05:56 T:139767225046976   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
22:05:56 T:139767225046976   DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
22:05:58 T:139766238615296   DEBUG: webserver: request received for /jsonrpc
I ran Kodi in a manual installed way from a ppa repository, where I had not problems installing aoen nox.
How I could solve this issue?
Thanks in advance.
most likely you need to force refresh the addon repo.
it's still listing the gotham skins on your end. after a refresh it should display the helix ones.
Worked.
Problem fixed. Thanks.
(2014-12-23, 23:13)hegg Wrote: [ -> ]After fixing lightdm autologin, everything is working so far.
would you mind explaining how you managed to get rid of autologin issue with lightdm ?
I haven't been able to find the solution and this will really help me.
Thanks. Nod
