Full Version: kodi crash on start up
hi need help kodi is crashing on start up and i dont now why!
this pc is very old but i have run on win7 xbmc but now on lubuntu it crash on start up i have
pent 4 2.0
2 g ram
raidon 9200
and crash log
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Qua Dez 24 16:16:16 WET 2014
Kodi Options:
Arch: i686
Kernel: Linux 3.13.0-43-generic #72-Ubuntu SMP Mon Dec 8 19:35:44 UTC 2014
Release: Ubuntu 14.04.1 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
16:16:08 T:3033970496 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:16:08 T:3033970496 NOTICE: -----------------------------------------------------------------------
16:16:08 T:3033970496 NOTICE: Starting Kodi (14.0 Git:ad747d9). Platform: Linux x86 32-bit
16:16:08 T:3033970496 NOTICE: Using Release Kodi x32 build
16:16:08 T:3033970496 NOTICE: Kodi compiled Dec 23 2014 by GCC 4.8.2 for Linux x86 32-bit version 3.13.11 (199947)
16:16:08 T:3033970496 NOTICE: Running on Ubuntu 14.04.1 LTS, kernel: Linux x86 32-bit version 3.13.0-43-generic
16:16:08 T:3033970496 NOTICE: FFmpeg statically linked, version: 2.4.4-xbmc-2.4.4-Helix
16:16:08 T:3033970496 NOTICE: Host CPU: Intel® Pentium® 4 CPU 2.00GHz, 1 core available
16:16:08 T:3033970496 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
16:16:08 T:3033970496 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
16:16:08 T:3033970496 NOTICE: special://masterprofile/ is mapped to: /home/luis/.kodi/userdata
16:16:08 T:3033970496 NOTICE: special://home/ is mapped to: /home/luis/.kodi
16:16:08 T:3033970496 NOTICE: special://temp/ is mapped to: /home/luis/.kodi/temp
16:16:08 T:3033970496 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
16:16:08 T:3033970496 NOTICE: Local hostname: luis-desktop
16:16:08 T:3033970496 NOTICE: Log File is located: /home/luis/.kodi/temp/kodi.log
16:16:08 T:3033970496 NOTICE: load settings...
16:16:08 T:3033970496 ERROR: PulseAudio: Failed to connect context
16:16:08 T:3033970496 NOTICE: PulseAudio might not be running. Context was not created.
16:16:08 T:3033970496 NOTICE: Found 1 Lists of Devices
16:16:08 T:3033970496 NOTICE: Enumerated ALSA devices:
16:16:08 T:3033970496 NOTICE: Device 1
16:16:08 T:3033970496 NOTICE: m_deviceName : @
16:16:08 T:3033970496 NOTICE: m_displayName : Default (Intel 82801DB-ICH4 Intel 82801DB-ICH4)
16:16:08 T:3033970496 NOTICE: m_displayNameExtra:
16:16:08 T:3033970496 NOTICE: m_deviceType : AE_DEVTYPE_PCM
16:16:08 T:3033970496 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
16:16:08 T:3033970496 NOTICE: m_sampleRates : 48000
16:16:08 T:3033970496 NOTICE: m_dataFormats : AE_FMT_S32NE
16:16:08 T:3033970496 NOTICE: Device 2
16:16:08 T:3033970496 NOTICE: m_deviceName : @:CARD=I82801DBICH4,DEV=0
16:16:08 T:3033970496 NOTICE: m_displayName : Intel 82801DB-ICH4
16:16:08 T:3033970496 NOTICE: m_displayNameExtra: Intel 82801DB-ICH4
16:16:08 T:3033970496 NOTICE: Device 3
16:16:08 T:3033970496 NOTICE: m_deviceName : iec958:CARD=I82801DBICH4,DEV=0
16:16:08 T:3033970496 NOTICE: m_displayNameExtra: Intel 82801DB-ICH4 - IEC958 S/PDIF
16:16:08 T:3033970496 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
16:16:08 T:3033970496 NOTICE: m_sampleRates : 32000,44100,48000
16:16:08 T:3033970496 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE
16:16:08 T:3033970496 NOTICE: Device 4
16:16:08 T:3033970496 NOTICE: m_deviceName : @:CARD=Live,DEV=0
16:16:08 T:3033970496 NOTICE: m_displayName : SB Live! 5.1 (@:CARD=Live,DEV=0)
16:16:08 T:3033970496 NOTICE: m_displayNameExtra: ADC Capture/Standard PCM Playback
16:16:08 T:3033970496 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000
16:16:08 T:3033970496 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
16:16:08 T:3033970496 NOTICE: Device 5
16:16:08 T:3033970496 NOTICE: m_deviceName : rear:CARD=Live,DEV=0
16:16:08 T:3033970496 NOTICE: m_displayName : SB Live! 5.1 (rear:CARD=Live,DEV=0)
16:16:08 T:3033970496 NOTICE: m_channels : UNKNOWN1,BL,BR
16:16:08 T:3033970496 NOTICE: Device 6
16:16:08 T:3033970496 NOTICE: m_deviceName : center_lfe:CARD=Live,DEV=0
16:16:08 T:3033970496 NOTICE: m_channels : UNKNOWN1,FC,LFE
16:16:08 T:3033970496 NOTICE: Device 7
16:16:08 T:3033970496 NOTICE: m_deviceName : iec958:CARD=Live,DEV=0
16:16:08 T:3033970496 NOTICE: m_displayNameExtra: Multichannel Capture/PT Playback S/PDIF
16:16:08 T:3033970496 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
16:16:08 T:3033970496 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:16:08 T:3033970496 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:16:08 T:3033970496 NOTICE: Default DVD Player: dvdplayer
16:16:08 T:3033970496 NOTICE: Default Video Player: dvdplayer
16:16:08 T:3033970496 NOTICE: Default Audio Player: paplayer
16:16:08 T:3033970496 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:16:08 T:3033970496 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:16:08 T:3033970496 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:16:08 T:3033970496 NOTICE: Loaded playercorefactory configuration
16:16:08 T:3033970496 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:16:08 T:3033970496 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:16:08 T:2899356480 NOTICE: Thread ActiveAE start, auto delete: false
16:16:08 T:2964372288 NOTICE: Thread AESink start, auto delete: false
16:16:09 T:3033970496 NOTICE: Running database version Addons16
16:16:09 T:3033970496 NOTICE: ADDONS: Using repository repository.xbmc.org
16:16:09 T:2953911104 NOTICE: Thread PeripBusCEC start, auto delete: false
16:16:09 T:2945518400 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
16:16:09 T:3033970496 NOTICE: Setup SDL
16:16:09 T:3033970496 NOTICE: Checking resolution 16
16:16:09 T:3033970496 NOTICE: Using visual 0xd7
16:16:10 T:3033970496 NOTICE: GL_VENDOR = Mesa Project
16:16:10 T:3033970496 NOTICE: GL_RENDERER = Mesa DRI R200 (RV280 5960) x86/MMX/SSE2 TCL DRI2
16:16:10 T:3033970496 NOTICE: GL_VERSION = 1.3 Mesa 10.1.3
16:16:10 T:3033970496 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
16:16:10 T:3033970496 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_occlusion_query GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_fragment_shader GL_EXT_texture_cube_map GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_shader_objects GL_ARB_vertex_program GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_texture_rectangle GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_texture_mirror_once GL_EXT_gpu_program_parameters GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_debug_output GL_ARB_sampler_objects GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_map_buffer_alignment GL_ARB_texture_storage GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
16:16:10 T:3033970496 ERROR: ResetRenderSystem() GL_MAX_TEXTURE_IMAGE_UNITS_ARB returned error 1280
16:16:10 T:3033970496 NOTICE: Running database version Addons16
16:16:10 T:3033970496 NOTICE: Running database version ViewModes6
16:16:10 T:3033970496 NOTICE: Running database version Textures13
16:16:10 T:3033970496 NOTICE: Running database version MyMusic48
16:16:11 T:3033970496 NOTICE: Running database version MyVideos90
16:16:11 T:3033970496 NOTICE: Running database version TV26
16:16:11 T:3033970496 NOTICE: Running database version Epg8
16:16:11 T:3033970496 NOTICE: start dvd mediatype detection
16:16:11 T:2907245376 NOTICE: Thread DetectDVDMedia start, auto delete: false
16:16:11 T:3033970496 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
16:16:11 T:3033970496 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
16:16:11 T:3033970496 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
16:16:12 T:3033970496 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:16:12 T:2889874240 NOTICE: Thread LanguageInvoker start, auto delete: false
16:16:12 T:3033970496 NOTICE: initialize done
16:16:12 T:3033970496 NOTICE: Running the application...
16:16:12 T:2889874240 NOTICE: -->Python Interpreter Initialized<--
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
many thanks
I would suggest you to install gdb to get a stack trace, which can help developers more.
gdb crash log
Date: Qua Dez 24 19:49:59 WET 2014
Kodi Options:
Arch: i686
=====> Core file: /home/luis/core (2014-12-24 19:49:59.828201339 +0000)
[New LWP 1737]
[New LWP 1943]
[New LWP 1944]
[New LWP 1945]
[New LWP 1946]
[New LWP 1954]
[New LWP 1955]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00000000 in ?? ()
Thread 7 (Thread 0xac2ffb40 (LWP 1955)):
#0 0xb6f205de in _PyObject_GC_New () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#1 0xb6f0b158 in PyFunction_New () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#2 0xb6f3c57e in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#3 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#4 0xb6f3f7ec in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#5 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#6 0xb6f40e23 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb6f411ce in PyImport_ExecCodeModuleEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0xb6f588c4 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#9 0xb6f59027 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#10 0xb6f5297c in PyImport_ImportModuleLevel () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#11 0xb6e62803 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#12 0xb6f08e19 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#13 0xb6ecf4f4 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#14 0xb6e79282 in PyEval_CallObjectWithKeywords () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#15 0xb6f3d3f9 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#16 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#17 0xb6f40e23 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#18 0xb6f411ce in PyImport_ExecCodeModuleEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#19 0xb6f588c4 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#20 0xb6f59027 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#21 0xb6f5297c in PyImport_ImportModuleLevel () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#22 0xb6e62803 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#23 0xb6f08e19 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#24 0xb6ecf4f4 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#25 0xb6e79282 in PyEval_CallObjectWithKeywords () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#26 0xb6f3d3f9 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#27 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#28 0xb6f40e23 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#29 0xb6f411ce in PyImport_ExecCodeModuleEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#30 0xb6f588c4 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#31 0xb6f59027 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#32 0xb6f5297c in PyImport_ImportModuleLevel () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#33 0xb6e62803 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#34 0xb6f08e19 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#35 0xb6ecf4f4 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#36 0xb6e79282 in PyEval_CallObjectWithKeywords () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#37 0xb6f3d3f9 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#38 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#39 0xb6f3f7ec in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#40 0xb6f3f8c2 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#41 0xb6f3f8c2 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#42 0xb6f3f8c2 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#43 0xb6f3f8c2 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#44 0xb6f3f8c2 in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#45 0xb6f40cbc in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#46 0xb6f40e23 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#47 0xb6f411ce in PyImport_ExecCodeModuleEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#48 0xb6f588c4 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#49 0xb6f59027 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#50 0xb6f5297c in PyImport_ImportModuleLevel () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#51 0xb6e62803 in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#52 0xb6f08e19 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#53 0xb6ecf4f4 in PyObject_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#54 0xb6e6a3ce in PyObject_CallFunction () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#55 0xb6eab31b in PyImport_Import () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#56 0xb6eaca5a in PyImport_ImportModule () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#57 0xb6ee443e in Py_NewInterpreter () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#58 0x089c5af9 in CPythonInvoker::execute(std:Confusedtring const&, std::vector<std:Confusedtring, std::allocator<std:Confusedtring> > const&) ()
#59 0x089c3dfc in CPythonInvoker::Execute(std:Confusedtring const&, std::vector<std:Confusedtring, std::allocator<std:Confusedtring> > const&) ()
#60 0x087ba3ce in CLanguageInvokerThread:Tonguerocess() ()
#61 0x097ce3a5 in CThread::Action() ()
#62 0x097ceabd in CThread:ConfusedtaticThread(void*) ()
#63 0xb7335f70 in start_thread (arg=0xac2ffb40) at pthread_create.c:312
#64 0xb606947e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 6 (Thread 0xb021cb40 (LWP 1954)):
#0 0xb778c424 in __kernel_vsyscall ()
#1 0xb733a12d in pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i686/../i486/pthread_cond_timedwait.S:245
#2 0x097ce947 in CThread::Sleep(unsigned int) ()
#3 0x088d9947 in MEDIA_DETECT::CDetectDVDMedia:Tonguerocess() ()
#4 0x097ce3a5 in CThread::Action() ()
#5 0x097ceabd in CThread:ConfusedtaticThread(void*) ()
#6 0xb7335f70 in start_thread (arg=0xb021cb40) at pthread_create.c:312
#7 0xb606947e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 5 (Thread 0xaf882b40 (LWP 1946)):
#1 0xb605a51b in poll () at ../sysdeps/unix/syscall-template.S:81
#2 0x0969ed48 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#3 0x0969ee20 in PERIPHERALS::CPeripheralBusUSB:Tonguerocess() ()
#6 0xb7335f70 in start_thread (arg=0xaf882b40) at pthread_create.c:312
Thread 4 (Thread 0xb0083b40 (LWP 1945)):
#2 0x096a1d90 in PERIPHERALS::CPeripheralBus:Tonguerocess() ()
#3 0x097ce3a5 in CThread::Action() ()
#4 0x097ceabd in CThread:ConfusedtaticThread(void*) ()
#5 0xb7335f70 in start_thread (arg=0xb0083b40) at pthread_create.c:312
#6 0xb606947e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 3 (Thread 0xb0ae2b40 (LWP 1944)):
#2 0xb687cf57 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#3 0xb6883222 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#4 0xb68904d5 in snd_pcm_mmap_writei () from /usr/lib/i386-linux-gnu/libasound.so.2
#5 0xb687ba28 in snd_pcm_writei () from /usr/lib/i386-linux-gnu/libasound.so.2
#6 0x0862d4f7 in CAESinkALSA::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#7 0x08615937 in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#8 0x08616d60 in ActiveAE::CActiveAESink::StateMachine(int, Actor:Tonguerotocol*, Actor::Message*) ()
#9 0x08617812 in ActiveAE::CActiveAESink:Tonguerocess() ()
#10 0x097ce3a5 in CThread::Action() ()
#11 0x097ceabd in CThread:ConfusedtaticThread(void*) ()
#12 0xb7335f70 in start_thread (arg=0xb0ae2b40) at pthread_create.c:312
#13 0xb606947e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 2 (Thread 0xacce1b40 (LWP 1943)):
#2 0x086114b0 in ActiveAE::CActiveAE:Tonguerocess() ()
#5 0xb7335f70 in start_thread (arg=0xacce1b40) at pthread_create.c:312
Thread 1 (Thread 0xb4d43740 (LWP 1737)):
19:49:51 T:3033806656 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:49:51 T:3033806656 NOTICE: -----------------------------------------------------------------------
19:49:51 T:3033806656 NOTICE: Starting Kodi (14.0 Git:ad747d9). Platform: Linux x86 32-bit
19:49:51 T:3033806656 NOTICE: Using Release Kodi x32 build
19:49:51 T:3033806656 NOTICE: Kodi compiled Dec 23 2014 by GCC 4.8.2 for Linux x86 32-bit version 3.13.11 (199947)
19:49:51 T:3033806656 NOTICE: Running on Ubuntu 14.04.1 LTS, kernel: Linux x86 32-bit version 3.13.0-43-generic
19:49:51 T:3033806656 NOTICE: FFmpeg statically linked, version: 2.4.4-xbmc-2.4.4-Helix
19:49:51 T:3033806656 NOTICE: Host CPU: Intel® Pentium® 4 CPU 2.00GHz, 1 core available
19:49:51 T:3033806656 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:49:51 T:3033806656 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
19:49:51 T:3033806656 NOTICE: special://masterprofile/ is mapped to: /home/luis/.kodi/userdata
19:49:51 T:3033806656 NOTICE: special://home/ is mapped to: /home/luis/.kodi
19:49:51 T:3033806656 NOTICE: special://temp/ is mapped to: /home/luis/.kodi/temp
19:49:51 T:3033806656 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
19:49:51 T:3033806656 NOTICE: Local hostname: luis-desktop
19:49:51 T:3033806656 NOTICE: Log File is located: /home/luis/.kodi/temp/kodi.log
19:49:52 T:3033806656 NOTICE: load settings...
19:49:52 T:3033806656 ERROR: PulseAudio: Failed to connect context
19:49:52 T:3033806656 NOTICE: PulseAudio might not be running. Context was not created.
19:49:53 T:3033806656 NOTICE: Found 1 Lists of Devices
19:49:53 T:3033806656 NOTICE: Enumerated ALSA devices:
19:49:53 T:3033806656 NOTICE: Device 1
19:49:53 T:3033806656 NOTICE: m_deviceName : @
19:49:53 T:3033806656 NOTICE: m_displayName : Default (Intel 82801DB-ICH4 Intel 82801DB-ICH4)
19:49:53 T:3033806656 NOTICE: m_displayNameExtra:
19:49:53 T:3033806656 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:49:53 T:3033806656 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
19:49:53 T:3033806656 NOTICE: m_sampleRates : 48000
19:49:53 T:3033806656 NOTICE: m_dataFormats : AE_FMT_S32NE
19:49:53 T:3033806656 NOTICE: Device 2
19:49:53 T:3033806656 NOTICE: m_deviceName : @:CARD=I82801DBICH4,DEV=0
19:49:53 T:3033806656 NOTICE: m_displayName : Intel 82801DB-ICH4
19:49:53 T:3033806656 NOTICE: m_displayNameExtra: Intel 82801DB-ICH4
19:49:53 T:3033806656 NOTICE: Device 3
19:49:53 T:3033806656 NOTICE: m_deviceName : iec958:CARD=I82801DBICH4,DEV=0
19:49:53 T:3033806656 NOTICE: m_displayNameExtra: Intel 82801DB-ICH4 - IEC958 S/PDIF
19:49:53 T:3033806656 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
19:49:53 T:3033806656 NOTICE: m_sampleRates : 32000,44100,48000
19:49:53 T:3033806656 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE
19:49:53 T:3033806656 NOTICE: Device 4
19:49:53 T:3033806656 NOTICE: m_deviceName : @:CARD=Live,DEV=0
19:49:53 T:3033806656 NOTICE: m_displayName : SB Live! 5.1 (@:CARD=Live,DEV=0)
19:49:53 T:3033806656 NOTICE: m_displayNameExtra: ADC Capture/Standard PCM Playback
19:49:53 T:3033806656 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000
19:49:53 T:3033806656 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
19:49:53 T:3033806656 NOTICE: Device 5
19:49:53 T:3033806656 NOTICE: m_deviceName : rear:CARD=Live,DEV=0
19:49:53 T:3033806656 NOTICE: m_displayName : SB Live! 5.1 (rear:CARD=Live,DEV=0)
19:49:53 T:3033806656 NOTICE: m_channels : UNKNOWN1,BL,BR
19:49:53 T:3033806656 NOTICE: Device 6
19:49:53 T:3033806656 NOTICE: m_deviceName : center_lfe:CARD=Live,DEV=0
19:49:53 T:3033806656 NOTICE: m_channels : UNKNOWN1,FC,LFE
19:49:53 T:3033806656 NOTICE: Device 7
19:49:53 T:3033806656 NOTICE: m_deviceName : iec958:CARD=Live,DEV=0
19:49:53 T:3033806656 NOTICE: m_displayNameExtra: Multichannel Capture/PT Playback S/PDIF
19:49:53 T:3033806656 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
19:49:53 T:3033806656 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:49:53 T:3033806656 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:49:53 T:3033806656 NOTICE: Default DVD Player: dvdplayer
19:49:53 T:3033806656 NOTICE: Default Video Player: dvdplayer
19:49:53 T:3033806656 NOTICE: Default Audio Player: paplayer
19:49:53 T:3033806656 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:49:53 T:3033806656 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:49:53 T:3033806656 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:49:53 T:3033806656 NOTICE: Loaded playercorefactory configuration
19:49:53 T:3033806656 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:49:53 T:3033806656 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:49:53 T:2899188544 NOTICE: Thread ActiveAE start, auto delete: false
19:49:53 T:2964204352 NOTICE: Thread AESink start, auto delete: false
19:49:53 T:3033806656 NOTICE: Running database version Addons16
19:49:54 T:3033806656 NOTICE: ADDONS: Using repository repository.xbmc.org
19:49:54 T:2953329472 NOTICE: Thread PeripBusCEC start, auto delete: false
19:49:54 T:2944936768 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
19:49:54 T:3033806656 NOTICE: Setup SDL
19:49:54 T:3033806656 NOTICE: Checking resolution 16
19:49:55 T:3033806656 NOTICE: Using visual 0xd7
19:49:55 T:3033806656 NOTICE: GL_VENDOR = Mesa Project
19:49:55 T:3033806656 NOTICE: GL_RENDERER = Mesa DRI R200 (RV280 5960) x86/MMX/SSE2 TCL DRI2
19:49:55 T:3033806656 NOTICE: GL_VERSION = 1.3 Mesa 10.1.3
19:49:55 T:3033806656 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
19:49:55 T:3033806656 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_occlusion_query GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_fragment_shader GL_EXT_texture_cube_map GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_shader_objects GL_ARB_vertex_program GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_texture_rectangle GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_texture_mirror_once GL_EXT_gpu_program_parameters GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_debug_output GL_ARB_sampler_objects GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_map_buffer_alignment GL_ARB_texture_storage GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
19:49:55 T:3033806656 ERROR: ResetRenderSystem() GL_MAX_TEXTURE_IMAGE_UNITS_ARB returned error 1280
19:49:55 T:3033806656 NOTICE: Running database version Addons16
19:49:55 T:3033806656 NOTICE: Running database version ViewModes6
19:49:55 T:3033806656 NOTICE: Running database version Textures13
19:49:55 T:3033806656 NOTICE: Running database version MyMusic48
19:49:56 T:3033806656 NOTICE: Running database version MyVideos90
19:49:56 T:3033806656 NOTICE: Running database version TV26
19:49:56 T:3033806656 NOTICE: Running database version Epg8
19:49:56 T:3033806656 NOTICE: start dvd mediatype detection
19:49:56 T:2955004736 NOTICE: Thread DetectDVDMedia start, auto delete: false
19:49:57 T:3033806656 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
19:49:57 T:3033806656 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
19:49:57 T:3033806656 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:49:57 T:3033806656 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:49:57 T:2888825664 NOTICE: Thread LanguageInvoker start, auto delete: false
19:49:57 T:3033806656 NOTICE: initialize done
19:49:57 T:3033806656 NOTICE: Running the application...
your GFX card is very old. check step 5 from http://forum.kodi.tv/showthread.php?tid=171690
