Full Version: Android crash
I have searched and not found a similar problem. I am trying to ready an android device to use on my bedroom tv. I have a zbox downstairs, central server and all of that works over mysql.
Every time i try to play a movie on the android device (beelink rk3288) and fast forward it crashed. This problem has been in every release candidate and the final kodi version. It seems to be a sync issue.
Any help would be appreciated.
DEBUG: ------ Window Init (VideoFullScreen.xml) ------
12:25:15 T:2031637120 INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
12:25:15 T:2031637120 NOTICE: Using GL_TEXTURE_2D
12:25:15 T:2031637120 DEBUG: GL: Requested render method: 0
12:25:15 T:2031637120 NOTICE: GL: Using MediaCodec render method
12:25:15 T:2031637120 NOTICE: GL: NPOT texture support detected
12:25:15 T:2031637120 DEBUG: CLinuxRendererGLES: Reorder drawpoints due to method change from 1 to 1024
12:25:15 T:2031637120 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
12:25:16 T:2142497984 DEBUG: Thread JobWorker 2142497984 terminating (autodelete)
12:25:17 T:2086805504 DEBUG: CDVDClock:Big Griniscontinuity - CDVDPlayerAudio::HandleSyncError2 - was:1996994.522589, should be:1955949.118409, error:-41045.404180
12:25:19 T:2086805504 DEBUG: CDVDClock:Big Griniscontinuity - CDVDPlayerAudio::HandleSyncError2 - was:3999339.243409, should be:3970354.715475, error:-28984.527934
12:25:21 T:2031637120 DEBUG: Keyboard: scancode: 0x16, sym: 0x0113, unicode: 0x0000, modifier: 0x0
12:25:21 T:2031637120 DEBUG: bool CApplication::OnKey(const CKey&): right (0xf083) pressed, action is StepForward
12:25:21 T:2088777192 DEBUG: CDVDPlayer::SetCaching - caching state 3
12:25:21 T:2088777192 DEBUG: demuxer seek to: 36602
12:25:21 T:2088777192 DEBUG: virtual bool CDVDDemuxFFmpeg::SeekTime(int, bool, double*) - unknown position after seek
12:25:21 T:2088777192 DEBUG: demuxer seek to: 36602, success
12:25:21 T:2031637120 DEBUG: CAnnouncementManager - Announcement: OnSeek from xbmc
12:25:21 T:2031637120 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek
12:25:21 T:2031637120 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
12:25:21 T:2086805504 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
12:25:21 T:2062823472 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
12:25:21 T:2086805504 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(42496000.000000, 1)
12:25:21 T:2088777192 DEBUG: CDVDPlayer::HandleMessages - player started 1
12:25:21 T:2062823472 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(42520000.000000, 0)
12:25:21 T:2062823472 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
12:25:24 T:2088777192 DEBUG: CDVDPlayer::HandleMessages - player started 2
12:25:24 T:2088777192 DEBUG: CDVDPlayer::SetCaching - caching state 0
12:25:24 T:2086805504 DEBUG: CDVDClock:Big Griniscontinuity - CDVDPlayerAudio::HandleSyncError1 - was:42450376.315909, should be:42496000.000000, error:45623.684091
Thanks so much
Please post a full debug log (wiki).
I just upgraded my box to the most recent rom that came out on the 25th and reinstalled kodi. Once installed kodi wouldn't open at all. I cleared the memory and cache for kodi and everything seems to be working great.
Thanks and hopefully this helps anyone else with similar problems.
I have a MXIII box and had a similar problem after installing Helix 14.0, it crashed every time I started it. As described, just go into the app menu off the settings icon, go to the Kodi app and clear cache and data. Bingo, works. Great job! Thanks!Big Grin
