2014-12-24, 21:44
I was hoping that Kodi fixed an issue that I had with XBMC on my Nexus 7 (2013) but the issues I was hoping was gone is still there and more annoyances have been introduced.
My setup is that I have a Qnap NAS that holds my library and a mysql database I share between my tablet and htpc. My HTPC works great even though it currently uses a slower wireless connection until I can drop a gigabit Ethernet run to it. I just upgraded all my devices to Kodi once the stable version was released.
First issue I have is that when watching HD movies, I get random pauses. Sometimes it has to re-buffer, and other times it just stops playing and goes back to the library list view. Highly annoying. If I use my file explorer (x-plore) and play the movie directly using MX Player, I get none of these issues. This is an issue I've had on XBMC as well.
The first new issue I found is trying to use the "Filter" function. On XBMC, clicking this would result in a few seconds pause before the menu comes up. On Kodi, it takes nearer to 20-30seconds and Kodi is pretty much locked up until it completes. Annoying when I watch a movie on my HTPC, stop it, then switch to my tablet to finish watching and I want to use the filter to find the "in progress" movie. I don't know if this is an issue because I'm using an external database or what, but highly annoying.
The last issue I've found is it always gives an error on close (Unfortunately, Kodi has stopped). While trying to see if there might have been an issue with my ROM, I upgraded it to Android 5.0.1 Lollipop and that's when this issue started up.
I've already tried clearing the cache and wiping the apps data, but that didn't solve the issues.
Any help would be appreciated.
