Since I can't use my usual skin, tried to install some new ones. Every one is giving me the "dependencies not met" error. Seems to be common, is it just that these skins need to be updated to support Helix, or is something else going on? Anyone else seeing this?
Oh, and Merry Christmas all
Just updated from Gotham which was crashing all the time to Helix. I am having the same issue. Every skin I click on gives me the same error message. Has anyone figured out a fix or work around?
Have you tried force refreshing the add-on repository (from the context menu)? This should install updates for all add-ons. Wait for the updates to finish and try installing new skins again.
I get the same issue but I also have no keypad on the keyboard when I choose '' Add Source'' for new repo
Have you tried force refreshing the repository?
Do you use a Helix compatible skin?
