Full Version: No HDMI Sound output in Kodi Helix after upgrade
May i first say happy christmas to everybody on this board!
Having just upgraded to Kodi Helix it is apparently using pulseaudio (on gotham i was using alsa) i can play videos fine, but no audio at all.
Can anyone shed some light or ideas on how i may solve?
Running on an ION system with a standalone login over the top of an ubuntu install.
Thank you for your time!
Maybe take a look at this:
http://kodi.wiki/view/PulseAudio#FAQ
Do you need pulseaudio? Are you planning to have sound from your desktop or do you use this device only for XBMC? If the last matches to you, I would purge pulseaudio completely and use alsa.
Thank you David1977 found that solution just before you posted it.
just ran this command in the terminal
sudo apt-get purge pulseaudio
and all my audio settings were back how i remember them!
If you don't want to purge pulseaudio completely you can still force Kodi to use ALSA by running it this way from a terminal window:
AE_SINK=ALSA kodi --standalone &
or
AE_SINK=ALSA kodi-standalone &
(Not sure what the difference is but I use the first). You can run this from a terminal window, a shell script, or whatever works best for you. The & at the end of the line causes it to run as a background task so your terminal window is freed or your shell script can continue.
