Hello guys I have a thinkpad t42 laptop with some radeon 7500 and installed linux mint xfce with lxde desktop. I tried also installing kodi and I get this: after it show the start screen it closes.
Below you have the crash log but more I don't know I have little knowledge of linux systems.
Hope you can point a solution as I like Kodi very much !
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Mon Oct 12 19:47:42 EEST 2015
Kodi Options:
Arch: i686
Kernel: Linux 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:44:48 UTC 2015
Release: Ubuntu 14.04.2 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/david/core (2015-10-12 19:47:41.215546759 +0300)
[New LWP 3012]
[New LWP 3014]
[New LWP 3015]
[New LWP 3016]
[New LWP 3017]
[New LWP 3025]
[New LWP 3026]
[New LWP 3027]
[New LWP 3028]
[New LWP 3029]
[New LWP 3031]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00000000 in ?? ()
Thread 11 (Thread 0xa86a6b40 (LWP 3031)):
#0 0xb77d5d50 in __kernel_vsyscall ()
#1 0xb6133e31 in select () at ../sysdeps/unix/syscall-template.S:81
#2 0x0876284c in XFILE::CCurlFile::CReadState::FillBuffer(unsigned int) ()
#3 0x08762ea7 in XFILE::CCurlFile::CReadState::Connect(unsigned int) ()
#4 0x08766421 in XFILE::CCurlFile::Open(CURL const&) ()
#5 0x0877a232 in XFILE::CFile::Open(CURL const&, unsigned int) ()
#6 0x0877a8f6 in XFILE::CFile::Open(std:
tring const&, unsigned int) ()
#7 0x0877d912 in XFILE::CFileCache::Open(CURL const&) ()
#8 0x0877a171 in XFILE::CFile::Open(CURL const&, unsigned int) ()
#9 0x0877a8f6 in XFILE::CFile::Open(std:
#10 0x08620c14 in ADDON::CRepository::FetchChecksum(std:
tring const&) ()
#11 0x08624775 in ADDON::CRepositoryUpdateJob::FetchIfChanged(std:
tring const&, std:
tring&, std::vector<std:
hared_ptr<ADDON::IAddon>, std::allocator<std:
hared_ptr<ADDON::IAddon> > >&) ()
#12 0x08624b5d in ADDON::CRepositoryUpdateJob:
oWork() ()
#13 0x08c9fcb0 in CJobWorker:
rocess() ()
#14 0x09982855 in CThread::Action() ()
#15 0x09982f6d in CThread:
taticThread(void*) ()
#16 0xb73a5f70 in start_thread (arg=0xa86a6b40) at pthread_create.c:312
#17 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 10 (Thread 0xab0b2b40 (LWP 3029)):
#0 __strlen_sse2_bsf () at ../sysdeps/i386/i686/multiarch/strlen-sse2-bsf.S:62
#1 0xb709e1ce in PyString_FromString () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#2 0xb703b8db in PyString_InternFromString () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#3 0xb70996e0 in PyType_Ready () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#4 0xb709a617 in PyType_Ready () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#5 0xb70a13cd in _Py_ReadyTypes () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#6 0xb70c15dd in Py_InitializeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb70c1f7b in Py_Initialize () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0x0884e4fd in XBPython::OnScriptInitialized(ILanguageInvoker*) ()
#9 0x0884964c in ILanguageInvoker::onExecutionInitialized() ()
#10 0x08856cde in CPythonInvoker::Execute(std:
tring const&, std::vector<std:
tring, std::allocator<std:
tring> > const&) ()
#11 0x08848fce in CLanguageInvokerThread:
rocess() ()
#12 0x09982855 in CThread::Action() ()
#13 0x09982f6d in CThread:
#14 0xb73a5f70 in start_thread (arg=0xab0b2b40) at pthread_create.c:312
#15 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 9 (Thread 0xb1744b40 (LWP 3028)):
#1 0xb73aa12d in pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i686/../i486/pthread_cond_timedwait.S:245
#2 0x09982df7 in CThread::Sleep(unsigned int) ()
#3 0x08a44977 in MEDIA_DETECT::CDetectDVDMedia:
rocess() ()
#4 0x09982855 in CThread::Action() ()
#5 0x09982f6d in CThread:
#6 0xb73a5f70 in start_thread (arg=0xb1744b40) at pthread_create.c:312
#7 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 8 (Thread 0xabbfdb40 (LWP 3027)):
#1 0xb612cc8b in poll () at ../sysdeps/unix/syscall-template.S:81
#2 0x0990d908 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#3 0x0990d9e0 in PERIPHERALS::CPeripheralBusUSB:
rocess() ()
#6 0xb73a5f70 in start_thread (arg=0xabbfdb40) at pthread_create.c:312
Thread 7 (Thread 0xac3feb40 (LWP 3026)):
#2 0x0990f930 in PERIPHERALS::CPeripheralBus:
rocess() ()
#3 0x09982855 in CThread::Action() ()
#4 0x09982f6d in CThread:
#5 0xb73a5f70 in start_thread (arg=0xac3feb40) at pthread_create.c:312
#6 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 6 (Thread 0xb1699b40 (LWP 3025)):
#2 0xb16ca77c in CEC::CCECClient:
rocess() () from /usr/lib/i386-linux-gnu/libcec.so.3.0
#3 0xb16cf059 in PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib/i386-linux-gnu/libcec.so.3.0
#4 0xb73a5f70 in start_thread (arg=0xb1699b40) at pthread_create.c:312
#5 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 5 (Thread 0xb3bfeb40 (LWP 3017)):
#2 0x09981374 in XbmcThreads::CEventGroup::wait(unsigned int) ()
#3 0x08be0f2d in CRemoteControl:
rocess() ()
#6 0xb73a5f70 in start_thread (arg=0xb3bfeb40) at pthread_create.c:312
Thread 4 (Thread 0xb43ffb40 (LWP 3016)):
#2 0xb6805bbd in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#3 0xb67f44ee in pa_mainloop_poll () from /usr/lib/i386-linux-gnu/libpulse.so.0
#4 0xb67f4d1d in pa_mainloop_iterate () from /usr/lib/i386-linux-gnu/libpulse.so.0
#5 0xb67f4df4 in pa_mainloop_run () from /usr/lib/i386-linux-gnu/libpulse.so.0
#6 0xb6805b5c in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#7 0xb5cb54dd in ?? () from /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-4.0.so
#8 0xb73a5f70 in start_thread (arg=0xb43ffb40) at pthread_create.c:312
#9 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 3 (Thread 0xb4d58b40 (LWP 3015)):
#1 0xb73a9d1d in pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i686/../i486/pthread_cond_wait.S:145
#2 0xb5cb485b in pa_cond_wait () from /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-4.0.so
#3 0xb680634e in pa_threaded_mainloop_wait () from /usr/lib/i386-linux-gnu/libpulse.so.0
#4 0x086a3766 in CAESinkPULSE::AddPackets(unsigned char**, unsigned int, unsigned int) ()
#5 0x08668057 in ActiveAE::CActiveAESink::OutputSamples(ActiveAE::CSampleBuffer*) ()
#6 0x08669300 in ActiveAE::CActiveAESink::StateMachine(int, Actor:
rotocol*, Actor::Message*) ()
#7 0x08669d02 in ActiveAE::CActiveAESink:
rocess() ()
#8 0x09982855 in CThread::Action() ()
#9 0x09982f6d in CThread:
#10 0xb73a5f70 in start_thread (arg=0xb4d58b40) at pthread_create.c:312
#11 0xb613bbee in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:129
Thread 2 (Thread 0xb0d50b40 (LWP 3014)):
#2 0x08664370 in ActiveAE::CActiveAE:
rocess() ()
#5 0xb73a5f70 in start_thread (arg=0xb0d50b40) at pthread_create.c:312
Thread 1 (Thread 0xb4d8a9c0 (LWP 3012)):
############# END STACK TRACE ###############
################# LOG FILE ##################
19:47:32 T:3034098112 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:47:32 T:3034098112 NOTICE: -----------------------------------------------------------------------
19:47:32 T:3034098112 NOTICE: Starting Kodi (16.0-ALPHA4 Git:1b13735). Platform: Linux x86 32-bit
19:47:32 T:3034098112 NOTICE: Using Release Kodi x32 build
19:47:32 T:3034098112 NOTICE: Kodi compiled Oct 12 2015 by GCC 4.8.4 for Linux x86 32-bit version 3.13.11 (199947)
19:47:32 T:3034098112 NOTICE: Running on Ubuntu 14.04.2 LTS, kernel: Linux x86 32-bit version 3.16.0-38-generic
19:47:32 T:3034098112 NOTICE: FFmpeg statically linked, version: 2.8-kodi-2.8.0-Jarvis-alpha3-HEVC
19:47:32 T:3034098112 NOTICE: Host CPU: Intel® Pentium® M processor 1.70GHz, 1 core available
19:47:32 T:3034098112 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:47:32 T:3034098112 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
19:47:32 T:3034098112 NOTICE: special://masterprofile/ is mapped to: /home/david/.kodi/userdata
19:47:32 T:3034098112 NOTICE: special://home/ is mapped to: /home/david/.kodi
19:47:32 T:3034098112 NOTICE: special://temp/ is mapped to: /home/david/.kodi/temp
19:47:32 T:3034098112 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
19:47:32 T:3034098112 NOTICE: Local hostname: david-ThinkPad-T42
19:47:32 T:3034098112 NOTICE: Log File is located: /home/david/.kodi/temp/kodi.log
19:47:32 T:3034098112 NOTICE: load settings...
19:47:32 T:3034098112 NOTICE: Found 1 Lists of Devices
19:47:32 T:3034098112 NOTICE: Enumerated PULSE devices:
19:47:32 T:3034098112 NOTICE: Device 1
19:47:32 T:3034098112 NOTICE: m_deviceName : Default
19:47:32 T:3034098112 NOTICE: m_displayName : Default
19:47:32 T:3034098112 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
19:47:32 T:3034098112 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:47:32 T:3034098112 NOTICE: m_channels : FL,FR
19:47:32 T:3034098112 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
19:47:32 T:3034098112 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
19:47:32 T:3034098112 NOTICE: Device 2
19:47:32 T:3034098112 NOTICE: m_deviceName : alsa_output.pci-0000_00_1f.5.analog-stereo
19:47:32 T:3034098112 NOTICE: m_displayName : Built-in Audio Analog Stereo
19:47:32 T:3034098112 NOTICE: m_displayNameExtra: Headphones / Amplifier (PULSEAUDIO)
19:47:32 T:3034098112 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:47:32 T:3034098112 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:47:32 T:3034098112 NOTICE: Default DVD Player: dvdplayer
19:47:32 T:3034098112 NOTICE: Default Video Player: dvdplayer
19:47:32 T:3034098112 NOTICE: Default Audio Player: paplayer
19:47:32 T:3034098112 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:47:32 T:3034098112 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:47:32 T:3034098112 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:47:32 T:3034098112 NOTICE: Loaded playercorefactory configuration
19:47:32 T:3034098112 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:47:32 T:3034098112 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:47:32 T:2966752064 NOTICE: Thread ActiveAE start, auto delete: false
19:47:32 T:3033893696 NOTICE: Thread AESink start, auto delete: false
19:47:33 T:3033893696 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:47:33 T:3034098112 NOTICE: Running database version Addons19
19:47:34 T:3034098112 NOTICE: ADDONS: Using repository repository.xbmc.org
19:47:34 T:3015699264 NOTICE: Thread RemoteControl start, auto delete: false
19:47:34 T:3034098112 NOTICE: Setup SDL
19:47:35 T:3034098112 NOTICE: Checking resolution 16
19:47:35 T:3034098112 ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:49, error_code:5, request_code:18 minor_code:0
19:47:36 T:3034098112 NOTICE: Using visual 0xd8
19:47:36 T:3034098112 NOTICE: GL_VENDOR = Mesa Project
19:47:36 T:3034098112 NOTICE: GL_RENDERER = Mesa DRI R100 (RV200 4C57) x86/MMX/SSE2 TCL DRI2
19:47:36 T:3034098112 NOTICE: GL_VERSION = 1.3 Mesa 10.1.3
19:47:36 T:3034098112 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
19:47:36 T:3034098112 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_occlusion_query GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_texture_cube_map GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_shader_objects GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_stencil_wrap GL_MESA_ycbcr_texture GL_ARB_shading_language_100 GL_ARB_vertex_buffer_object GL_OES_read_format GL_ARB_texture_rectangle GL_EXT_texture_compression_dxt1 GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_texture_mirror_once GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_debug_output GL_ARB_sampler_objects GL_ARB_get_program_binary GL_ARB_robustness GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_map_buffer_alignment GL_ARB_texture_storage GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
19:47:36 T:3034098112 ERROR: ResetRenderSystem() GL_MAX_TEXTURE_IMAGE_UNITS_ARB returned error 1280
19:47:38 T:2889870144 NOTICE: Thread PeripBusCEC start, auto delete: false
19:47:38 T:2881477440 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
19:47:38 T:3034098112 NOTICE: Running database version Addons19
19:47:38 T:3034098112 NOTICE: Running database version ViewModes6
19:47:38 T:3034098112 NOTICE: Running database version Textures13
19:47:38 T:3034098112 NOTICE: Running database version MyMusic54
19:47:38 T:3034098112 NOTICE: Running database version MyVideos99
19:47:38 T:3034098112 NOTICE: Running database version TV29
19:47:38 T:3034098112 NOTICE: Running database version Epg11
19:47:38 T:3034098112 NOTICE: start dvd mediatype detection
19:47:38 T:2977188672 NOTICE: Thread DetectDVDMedia start, auto delete: false
19:47:38 T:3034098112 WARNING: CSkinInfo: failed to load skin settings
19:47:40 T:3034098112 WARNING: Previous line repeats 1 times.
19:47:40 T:3034098112 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
19:47:40 T:3034098112 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
19:47:40 T:3034098112 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:47:40 T:3034098112 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:47:40 T:2869635904 NOTICE: Thread LanguageInvoker start, auto delete: false
19:47:40 T:3034098112 NOTICE: ActiveAE DSP - starting
19:47:40 T:3034098112 NOTICE: initialize done
19:47:40 T:3034098112 NOTICE: Running the application...
19:47:40 T:2833939264 NOTICE: Thread Timer start, auto delete: false
19:47:40 T:2825546560 NOTICE: Thread JobWorker start, auto delete: true
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
