2014-12-27, 05:20
Hi all, setup is: minix x8h plus, router, synology nas.
Did a modem reset (turned off and on) which normally is required once a per week for various reasons.
First time with a XMBC device connected (normally boxee box, never a drama).
When I select to play a movie from the library it says "This files no longer available would you like to remivevfrom the library".
Issue is nothing XMBC and network related works anymore, when I go to select new share I get a "connection timed out" error. The path IP is correct nothing has changed accept I turned the router /modem off/on.
You tube/google etc still work on the minix.
PS: the media centre app finds everything and works fine.
