2014-12-27, 18:59
Does anyone know of a way to keep the Home Menu stationary, and allow the focus to move up and down on the screen instead of having the focus stay centered and the menu moving?
(2014-12-29, 07:44)ashish1t Wrote: [ -> ]Thanks for your request. I am too looking for a vertical home screen. The hybrid development was an excellent skin until it changed to horizontal only home screen menu. Others did not appeal as much. Would be nice to have one soon. Thanks a ton folks.Amber has a setting for a vertical homescreen. It actually looks and works really well. If you haven't tried it you really should.
(2015-01-09, 21:11)Hansje Wrote: [ -> ]Would like to second the request for a stationary, vertical home menu.
As it is now, it's virtually impossible for me to select a menu item with the mouse or Logitec Dinovo connected to the HTPC!
Thanks for an otherwise great skin!
(2015-01-12, 00:00)Calum Wrote: [ -> ]Use the arrow keys if you're using a keyboard. This skin works great with a remote.
#770: <posy>200</posy>
#780: <movement>12</movement>
#767: <control type="wraplist" id="300" description="Main Bar">
(2015-05-28, 14:04)garbokawa Wrote: [ -> ]Please locate Includes_Vertical_Home.xml and modify as follows:
Code:#770: <posy>200</posy>
Notes:
Line #770: Positioning the menu contents - choice of personal taste
Line #780: Makes the menu stationary = Choose 8 or any number above 8.
Line #767: Change only if you want a cyclical menu ... otherwise, leave it as "fixedlist"
Also you can change the predetermined highlight in the menu item ... in the <focusposition>2</focusposition> at line# 779.
The focusposition starts at 0 thru n-1 of your fixed list where 0 is the first item in the menu and n-1 is the last.
Here focusposition = 2 highlights Movies in the menu in an unaltered sequence.
Cheers!
GK
