2014-12-28, 00:50
I normally keep Kodi in windowed mode, and maximized for convenience. However there are two instances where it loses maximized status that I don't understand, and wondered if this should be marked as a bug.
1) It doesn't remember maximized state after quitting and restarting the program. This should be a trivial settings flag, and I'm not sure why it's not being saved.
Edit 2: Found that there's a flag that can be set on the program startup property page that can force this. Never mind on the first question, then.
2) If I switch to fullscreen mode (backslash key), when returning to windowed mode the maximized setting is lost, and the window itself is shifted relative to where it was last left.
Is there a way to fix this problem, or should I mark this as a bug?
Edit: Guess I should note that I'm on Windows 7, and this might also be better placed in the Windows subforum.
