Full Version: Updating to Kodi from 12.2 stable with XBMCbuntu (11.10) as base install
I'm trying to update to the current release of Kodi from XBMC 12.2. I've already run 'sudo apt-get update', 'sudo apt-get upgrade' and then 'sudo do-release-upgrade'.
I've added the following to /etc/apt/sources.list as it looks like I'm at EOL with support
## EOL upgrade sources.list
# Required
deb http://old-releases.ubuntu.com/ubuntu/ oneiric main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ oneiric-updates main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ oneiric-security main restricted universe multiverse
It's gone through and done various updates, I've rebooted and I'm still running 11.10.
'sudo apt-get install xbmc' reports its at the latest release. 'sudo apt-get install kodi' reports no package by that name..
I'd really rather not do a fresh install as I have a lot of other installed software on the system.. can anyone please throw some light at this for me?
Thanks,
Doug
what is the output when you do-release-upgrade ?
doug@minipc:~$ sudo do-release-upgrade
[sudo] password for doug:
Checking for a new Ubuntu release
No new release found
It pointed me to a page that I'd been to already, though had ignored a step as the release I had was LTS so I left the prompt=LTS originally, though have just changed it to normal and it appears to be going okay.
If I bugger it all up, then I guess I'll deal with reinstalling fresh.
I find a complete reinstall to be my standard approach to upgrading ubuntu. PITA though it is.
it appeared to be upgrading but at the end, again, I'm left with 11.10. *grumble*
Checking package manager
Reading package lists... Done
Building dependency tree
Reading state information... Done
Building data structures... Done
Calculating the changes
No candidate ver:  libapt-inst1.3
...... (20 odd messages of the same)
No candidate ver:  libshairplay0
No candidate ver:  linux-image-3.0.0-16-generic
No candidate ver:  linux-image-3.0.0-17-generic-pae
The software on this computer is up to date.
There are no upgrades available for your system. The upgrade will now
be canceled.
Do you want to start the upgrade?
Continue [yN]  Details [d]y
Fetching
Fetched 0 B in 0s (0 B/s)
Upgrading
apport: unrecognized service
Searching for obsolete software
System upgrade is complete.
Restart required
To finish the upgrade, a restart is required.
If you select 'y' the system will be restarted.
I'm just stuck living in the past... will wait till next year (next weekend) when I have more time to do a fresh install.
Unless anyone else has an idea to try?
As I say, I usually reinstall. Google may be your friend. It is essentially a ubuntu problem at this point.
