Full Version: Ember 1.4.0.7 - Cannot Install VLC (only portable mode) [SOLVED]
Hello.
I cannot install VLC on my company laptop (no admin privileges): I can only use the portable version. After the first scan, Ember does not show any movie. The issue came out for the first time with v. 1.4.0.7 and I believe it has to do with the need to have VLC installed. How can I "convince" Ember to look in my portable installation folder instead of the "default" (i.e. Program Files) VLC location?
Thank you very much for your support and congratulations for the best media scraper around!
[EDIT] I reinstalled Ember from scratch and now everything works perfectly! Blush
