Full Version: Structure's folders for renamer
Hi. First of all I would like to thank the tinyMediaManager team for this amazing piece of software...;-)
I have a question:
My folder's structure is set in this manner:
C:\film\divx\film.mkv
C:\film\dvd\film2.mkv
C:\film\high definition\film3.mkv
When I have to select the datasources in the general menu I select: "C:\film\"
The problem is that when I rename a movie using the renamer tool I can't keep the original structure with the subfolder (divx, dvd, high definition) but I get the structure ("C:\film\film.mkv").
The only method I figured out for solving this problem is to choose the three datasources separated in the general menu (C:\film\divx\ ; C:\film\dvd\ ; C:\film\high definition\)
is there a possibility for solving this problem and selecting only the parent folder?
Thanks in advance ;-)
you did it the right way Wink
In your case, you have to choose 3 different data sources - these are 3 different types of movies.
thanks mlaggner ;-)
The only problem is that I have 6 hard disk structured in this manner so I have to use 18 data sources... :-)
