2014-12-29, 19:54
Ok I am having issues getting mySQL setup to work with KODI.
I am running a QNAP 870Pro with HD Station/XBMC 13.2
I have mysql turned on and using default port.
I have phpMyAdmin installed on Qnap to access mysql database.
Server Version 5.1.36
phpMyAdmin Version 4.1.13[/quote]
in phpMyAdmin I have ran the following code
then I have created the advancedsettings.xml and placed it into the correct folder
But when I run XBMC the databases are never created.
Looked at the logs and I get this:
I have checked and rechecked the permissions in phpMyAdmin and the xbmc user has all permissions.
I have re-initialized mySQL (reset) and reinstalled XBMC, so both were fresh. Still have same issue.
Note: I can connect to mysql using mysql workbench with the xbmc login and pass with not issues with full rights
Any thoughts?
PHP Code:
CREATE USER 'xbmc' IDENTIFIED BY 'xbmc';
GRANT ALL ON *.* TO 'xbmc'@'%' IDENTIFIED BY 'xbmc';
<advancedsettings>
<videoscreen>
<screen>0</screen>
</videoscreen>
<cputempcommand>sed -e 's/000$/ C/' /sys/class/hwmon/hwmon0/device/temp1_input</cputempcommand>
<gputempcommand>sed -e 's/000$/ C/' /sys/class/hwmon/hwmon0/device/temp1_input</gputempcommand>
<video>
<playcountminimumpercent>101</playcountminimumpercent>
</video>
<videodatabase>
<type>mysql</type>
<host>192.168.0.53</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
</advancedsettings>
08:54:37 T:4110825216 DEBUG: Initialize, updating databases...
08:54:37 T:4110825216 NOTICE: Running database version ViewModes6
08:54:37 T:4110825216 NOTICE: Running database version Textures13
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic46 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic45 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic44 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic43 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic42 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic41 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic40 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic39 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic38 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic37 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic36 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic35 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic34 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic33 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic32 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic31 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic30 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic29 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic28 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic27 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic26 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic25 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic24 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic23 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic22 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic21 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic20 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic19 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyMusic18 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to create new database
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos78 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos77 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos76 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos75 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos74 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos73 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos72 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos71 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos70 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos69 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos68 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos67 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos66 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos65 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos64 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos63 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos62 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos61 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
08:54:37 T:4110825216 ERROR: Unable to open database: MyVideos60 [1045](Access denied for user 'xbmc'@'QNAP870' (using password: YES))
Any thoughts?
