Full Version: DTS passthrough problem after upgrade to Kodi
Pages: 1 2 3
Hi All.
XBMCBuntu, xbmc upgraded to Kodi.
I have a problem with DTS audio passtrough. If i play some movie with DTS audio my amplifier properly detects "DTS" but hear only two channels.
System uses alsa drivers.
Thanx for any suggestions.
Set your settings level to expert and post a screenshot from your audio settins please....
And a Debug Log while playing one of those dts files.
Greetings
Hi. Sorry for photos but i don't know how to take a screenshot from bash.
This is my config:
Debug log:
https://www.dropbox.com/s/ot9kjm32331yxrv/kodi.log?dl=1
Are you sure the meat loaf iso is in more than 2 channels. I searched for it, but can't find a blu ray...only the dvd and this has dolby digital 2.0. Did you try playing other dts files? Are those playing fine and you have the issue only with this one? If you have issues with other files, could you please paste a Debug Log from playing those as well? The log itself looks fine as far as i can see.
Btw...dont place logfiles for download. There are many pastebin sites, where you are able to paste this...one is pastebin.com for example.
(2014-12-31, 00:27)David1977 Wrote: [ -> ]Are you sure the meat loaf iso is in more than 2 channels.
Yes i am sure. Aplituner detects "DTS" signal but hear only two channels. I have this problem with every material contains DTS audio.
(2014-12-31, 00:27)David1977 Wrote: [ -> ]I searched for it, but can't find a blu ray...only the dvd and this has dolby digital 2.0.
http://www.discogs.com/Meat-Loaf-With-Me...se/1892973
See notes:
Audio: Dolby Digital: 2.0 Stereo, Dolby Digital: 5.1 Surround, DTS 5.1 Surround
(2014-12-31, 00:27)David1977 Wrote: [ -> ]Did you try playing other dts files? Are those playing fine and you have the issue only with this one? If you have issues with other files, could you please paste a Debug Log from playing those as well? The log itself looks fine as far as i can see.
I have this problem with any material containing DTS audio. After work i give new debug log from another one.
(2014-12-31, 00:27)David1977 Wrote: [ -> ]Btw...dont place logfiles for download. There are many pastebin sites, where you are able to paste this...one is pastebin.com for example.
ok, sorry for this
ok, this is kodi.log from today:
http://pastebin.com/UUdXADCV
Hi. I downloaded DTS test file from here: http://www.digital-digest.com/movies/mov...type=dolby
DTS Piano.
This one not working too. Only two channels...
Change your AVR's setting. If the AVR detects DTS - the job is done for us. We don't touch the dts signal at all.
fritsch: DTS-HD works fine. I hear all channels. AVR settings are ok. On Gotham i have no problem with DTS on the same AVR.
Did you see my debug.log ?
There is some errors:
21:01:55 T:139911571138304 WARNING: could not find codec parameters for Dido - Live At Brixton Academy/DIDO_LIVE_AT_BRIXTON_ACADEMY.ISO
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Audio: passthrough - Opening
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Audio: passthrough - Failed
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
21:01:55 T:139911571138304 DEBUG: CDVDAudioCodecFFmpeg::Open() Unable to find codec 0
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Audio: FFmpeg - Failed
21:01:55 T:139911571138304 ERROR: Unsupported audio codec
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Opening
21:01:55 T:139911571138304 DEBUG: Open - Unable to find codec 0
21:01:55 T:139911571138304 DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Failed
21:01:55 T:139911571138304 ERROR: OpenStream - Unable to init overlay codec
21:01:55 T:139911571138304 DEBUG: OnPlayBackStarted: play state was 1, starting 1
XBMC Gotham was updated via apt-get install kodi. apt-get asked to remove xbmc. I replied yes. Maybe this is wrong way to update Xbmcbuntu from Gotham to Kodi ?
If i play any DVD with DTS audio on the same AVR i have DTS with every channel (5.1).
Hi fritsch.
I don't cut log files. Full log is in #6 post. I chose few lines from debug log to show you that something wrong.
ok
Test.avi - AVR detect DD Audio - i hear every 5.1 channel
English.dts - AVR detect DTS audio - i hear only front speakers.
Debug log:
http://pastebin.com/Dn4y4Pvr
That's not a full log as the audio device properties is missing from the beginning of the log, this is populated when Kodi is started.
ahh, ok
Full debug log:
http://pastebin.com/6Z6F9Ux7
Hi All Smile
Any clue ?
Fritsch ? Do you have an idea ?
Pages: 1 2 3
