Full Version: Keyboard not working in "Add Source" dialog
the keyboard is not working on the "Add Source" dialog within Helix on my MacBook (Yosemite). Everytime i want to change the source name, nothing happens. Keyboard is working everywhere else, no problems to change movie titles, series names, ....
I'm using Confluence (and tried a mod aswell with same issue).
Log: http://pastebin.com/NqyRM6eh
read http://kodi.tv/kodi-14-0-helix-unwinds/
Select a working skin
Did you read that i tried with default Confluence? And yes, i have chosen a layout - and i have no trouble on a Windows machine, only on OS X
You might want to double check. Your log shows you using "skin.helix"
10:51:17 T:140735176422144    INFO:   load skin from: /Users/ben/Library/Application Support/Kodi/addons/skin.helix (version: 1.0)
and not "skin.confluence"
Confluence works on my copy of Kodi v14.0 on OS X, including the on-screen-keyboard.
Yes, as i said ---> "I'm using Confluence (and tried a mod aswell with same issue)"
But after reinstall everything is working now, even the modded Confluence version (skin.helix)
