With the last API Update on trakt.tv the possibility to lists all comments of a user for a movie was implemented. I waited for this so I can add some kind of review/note system in Ember so a user can make some notes when he watched a movie and sync those with to trakt.tv. The idea is based on IMDB lists/comment mechanism, i.e.
http://www.imdb.com/list/ls053770931/
EDIT:
Just quick update to request:
http://bugs.embermediamanager.org/thebug...issues/224
Now you can upload movies/episodes to your watch history and also remove movies/shows from it within Ember:
Hello
would it be possible to download trakt.tv Lists and save as m3u playlists to an extra folder? So dont need to save as tags
i ask this because it would make a lot things easier and we could use this lists with the addon "Playlist Loader"
maby it could even import csv files (from imdb playlists) and convert to this m3u
(2015-11-28, 13:25)Romek_original Wrote: [ -> ]Hello
Hi I'm not sure I understand the idea of saving a trakt.tv list as playlist. So i.e. take this movie list from a random user on trakt.tv:
http://trakt.tv/users/_varg/lists/great-...r-heard-of
As far as I understand now what you wish is to do a lookup of every movie in that list and check if its already in Ember library and then automatically put the moviepath of every found movie in a playlist and export it?
i dont know when this even would be possible
as far as i know the .m3u format is used for mp3 playlists and streaming playlists
with the addon "Playlist loader" i can load m3u files and have the playlist
so i just need something to convert the lists from trakt.tv or imdb (csv files) to .m3u
like my watchlist from trakt.tv to watchlist.m3u
this saved in a playlist folder somewhere in my movie database (like the folder for all movieset artworks)
so it would not be saved to "tags"
(2015-11-28, 17:04)Romek_original Wrote: [ -> ]i dont know when this even would be possible
Understand I will put this on my to-do list - no promise though
hello sir - i just found the addon "Trakt.tv List Manager" - never checked it before - and it does exact what i want. So just forget what i wrote before
(2015-11-28, 18:58)Romek_original Wrote: [ -> ]hello sir - i just found the addon "Trakt.tv List Manager" - never checked it before - and it does exact what i want. So just forget what i wrote before
Glad that it works for you - nevertheless I just added the function to export a userlist from trakt.tv to .m3u playlist which also contains correct path to all the movies which are avalaible:
For this to work you need to configure the new Kodi Interface in Ember as the Kodi pathes are only configured there. Result:
Output:
#EXTM3U
#EXTINF:0,Predestination
nfs://192.168.2.200/Media_2/Movie/Horror/Predestination/Predestination.web-dl.iso
#EXTINF:0,Psycho
nfs://192.168.2.200/Media_2/Movie/Horror/Psycho/Psycho.mkv
