2015-05-28, 15:25
2015-06-21, 13:57
2015-06-21, 15:10
Great, but on the repo ist only the skin.aeon.nox.xbmcmania.helix-4.2.4a.zip
2015-06-22, 15:54
(2015-06-21, 15:10)Slipass Wrote: [ -> ]Great, but on the repo ist only the skin.aeon.nox.xbmcmania.helix-4.2.4a.zipI have a post with same question. Wrong ver in repo.
2015-06-22, 16:11
Be patient, I,m very busy this days
2015-07-25, 14:53
Hi, I notice this skin updated on my machines yesterday, has this update enabled compatibility with the new kodi 15.0 release?
2015-08-18, 18:02
I always use this skin, I'm very happy with it
2015-09-13, 12:26
does anyone know how I get always standard triple on
2015-09-20, 20:00
How can I change the default image background from the film strip? When I go into a plugin I would like a different default image.
Where can I download the English textures at?
Thanks for all your work!
2015-09-21, 08:28
I only can see confluence and confluence color icon on the repo. What have I done wrong?
2015-09-22, 10:59
(2015-04-19, 17:19)MGMan Wrote: [ -> ]Am I doing something wrong I am on Kodi Helix 14.2 , I have downloaded the repo and installed it from zip but I only have 2 skins on it
one is the regular confluence skin and the other is a hybrid skin, can't see any Aeon Nox one in this repo ?
The same hereā¦ Any answer?
2015-09-24, 20:27
can you configure xbmc (kodi) so it always takes external srt infront of all others
2015-10-15, 22:15
How do I change the spanish to english in this skin??
It says use the texture tool, but are there any instructions? I like this skin other then the language. Dont want to have to change to something else..
2015-12-02, 19:59
yes how to change it to english in this skin>
2015-12-17, 09:49
Will XBMCMania be updated for Isengaard/Jarvis soon?
I have some strange behavior in Isengaard that started recently, which is that when I boot my HTPC into Kodi with XBMCMania, I only get Kodi logo, see the cursor, and then the screen goes black and I have to Alt-F4. If I however open up Kodi again after the initial startup, then it loads into the home menu properly. This is driving me nuts, I have tried many things, and all I can conclude is that XBMCMania is the only skin with this behavior. I'm also using Kodi DSPlayer, but still, all other skins work perfectly when running Kodi as a startup item, while XBMCMania fails.
This is such a shame because XBMCMania is by far the best skin design- and UI-wise, but the performance is severely lacking in some cases and updates are scarce.
