2015-01-01, 15:44
Just fresh installed Kodi[buntu] and also upgraded the graphics card to Radeon HD6450 after using NVIDA for long time. it is working fine when I connect the box to a computer monitor (using HDMI to DVI cable) but the moment I hook it up to the TV, I don't get anything after the purple Kodi splash screen animation. Screen goes blank and stays like that forever.
the card The card appears to be detected properly:
Did anyone see the similar thing? Or any idea what's I'm missing? Best!
root@htpc:~# lshw -c video
*-display
description: VGA compatible controller
product: Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:46 memory:d0000000-dfffffff memory:fe9c0000-fe9dffff ioport:c000(size=256) memory:fe9a0000-fe9bffff
root@htpc:~# lspci | grep VGA
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
