2015-01-02, 15:06
I am a total novice to Linux and could really use some help! I am sure the answer is obvious but I am stuck. I am running Ubuntu 14.04.1 Server so no GUI, command line only. I have followed the Kodi installation. As far as I can see it went fine. I then created the autostart script from here; http://kodi.wiki/view/HOW-TO:Autostart_XBMC_for_Linux (section 3). I installed XINIT as it wasn't available on my installation and made a couple of mods to get over permission issues but Kodi doesn't start. As a newby I don't know where to look to see what the issue is. I am using Webmin so I can see that there is no process running call XMBC. My script is;
#! /bin/sh
### BEGIN INIT INFO
# Provides: xbmc
# Required-Start: $all
# Required-Stop: $all
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: starts instance of XBMC
# Description: starts instance of XBMC using start-stop-daemon and xinit
### END INIT INFO
############### EDIT ME ##################
# path to xinit exec
DAEMON=/usr/bin/xinit
# startup args
DAEMON_OPTS=" /usr/local/bin/xbmc --standalone -- :0"
# script name
NAME=xbmc
# app name
DESC=XBMC
# user
RUN_AS=martin
# Path of the PID file
PID_FILE=/var/run/xbmc.pid
############### END EDIT ME ##################
test -x $DAEMON || exit 0
set -e
case "$1" in
start)
echo "Starting $DESC"
sudo start-stop-daemon --start -c $RUN_AS --background --pidfile $PID_FILE --make-pidfile --exec $DAEMON -- $DAEMON_OPTS
stop)
echo "Stopping $DESC"
sudo start-stop-daemon --stop --pidfile $PID_FILE
restart|force-reload)
echo "Restarting $DESC"
sleep 5
N=/etc/init.d/$NAME
echo "Usage: $N {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0
Another question; when I do get Kodi started how do I access it? The web interface is disabled by default so how do I change that? Presumably then I can just do http://n.n.n.n:8080 ?
#! /bin/sh
### BEGIN INIT INFO
# Provides: xbmc
### END INIT INFO
# startup args
# script name
NAME=xbmc
# app name
DESC=XBMC
# user
RUN_AS=martin
set -e
case "$1" in
start)
stop)
sleep 5
N=/etc/init.d/$NAME
exit 1
esac
exit 0
