2015-01-03, 13:30
I am trying to install Kodi and when I run
sudo apt-get install kodi I get the following.
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package kodi
I added the repo to my source list. What am I doing wrong? Thanks in advance.
I also tried the following:
root@kali:~# apt-get install xbmc
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xbmc : Depends: xbmc-bin (>= 2:12.2~git20130502.1706-frodo-0oneiric) but it is not going to be installed
Depends: xbmc-bin (< 2:12.2~git20130502.1706-frodo-0oneiric.1~) but it is not going to be installed
Recommends: python-qt3 but it is not installable
Recommends: xbmc-pvr-mythtv-cmyth but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
