Full Version: Create loading plugin screen or blank title
I use plugins a lot, YouTube, DUMP.com, Apple Trailers etc.
On my Raspberry Pi / OpenElec system it takes about 5 seconds or more to load a plugin.
The issue is that when a plugin is loading, the title that is displayed in the top left corner shows , shows the title of the previous plugin until the selected plugin fully loads.
This is confusing as it appears that you've selected the wrong plugin - until the plugin is loaded.
The feature request would be to replace the title with 'Plugin Loading...' until the plugin completes loading.
Cheers.
(I'm not sure if this is an Amber issue or a Kodi issue??)
