Full Version: Cheapest but reliable way to run Pulsar
I have the mx3 and the fire tv
I love pulsar, easy and reliable. But doesn't run on Android...
I'm willing to go to a htpc is NEEDED... but hate the fact of a dedicated Pc just for xbmc..
What are your suggestions??
Kodi/xbmc is designed to run on a dedicated htpc.
I'm also pretty sure you can flash an openelec port on the mxIII which will most likely enable pulsar on your box.
(2015-01-03, 17:04)enen92 Wrote: [ -> ]Kodi/xbmc is designed to run on a dedicated htpc.
If I can do that I will love u forever. Googling now !
For anyone else looking...
OpenElec port
http://amlinux.ru/image/5.0.0/
Thank you enen92!
Did you manage to get Pulsar add on working ob your mxIII with the openelec build?
Did you manage to get Pulsar working on the mxIII with the openelec build?
