2015-01-03, 19:35
After I installed kodi using the wiki guide when it open the mouse became invisible and I cant change the options from menu, using the arrow keys it move like something is pulling it back so I can never get the configuration menu and I can't change nothing.
I already removed everything and installed again but the same problem persist.
sudo apt-get install python-software-properties pkg-config
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi
