Full Version: Got an issue with filter on GetMovies
I've trying to filer my movie listing by genreid but i'm getting this JSON returned:
{"error":{"code":-32602,"data":{"method":"VideoLibrary.GetMovies","stack":{"message":"Received value does not match any of the union type definitions","name":"filter","property":{"name":"order","type":"string"},"type":"object"}},"message":"Invalid params."},"id":1,"jsonrpc":"2.0"}
The JSON I'm posting looks like this:
{"jsonrpc":"2.0","method":"VideoLibrary.GetMovies","params":{"limits":{"start":0,"end":20},"filter":{"field":"genreid","operator":"is","value":1},"properties":["art","rating","genre","imdbnumber","plot","file","showlink","tag","trailer","year","streamdetails"],"sort":{"order":"descending","method":"dateadded","ignorearticle":true}},"id":1}
I've looked through so many KODI pages to try work out what i'm doing wrong, but I can't seem to work it out, I'm sure it's something simple if someone could help me out that would be great
There's something wrong with the error message. The
is wrong. But the request is wrong as well.
Either you need to specify the filter as
"filter": { "genreid": 1 }
(which can't be combined with other filters) or you need to use the genre name instead of its ID i.e.
"filter": { "field": "genreid", "operator": "is", "value": 1 }
Thanks for your help I was very confused by the error.
I'll do the first example you suggested and report back
