2015-01-04, 16:59
v14 running on a Chromebox. Connected with HDMI to TV. TV is connected to a Logitech Z-5500 with an optical cable.
Problem 1: I can't get DTS or even dolby digital to work. The Logitech display always displays "PL II Movie", which as far as I understand, basically means it gets a stereo signal and just simulates surround? I've tried both enabling DTS passthrough and disabled. I'll post a photo of the settings later.
Problem 2: On regular audio (not dts/Dolby Digial) the sound is a little distorted. Sounds like the volume is adjusted higher than the sound system can handle, even though i play at low volumes. A little hard to explain... I guess it feels like Kodi outputs the sound at 120% volume. I did not have this issue with XBMC on my Apple TV (on the same tv/sound hardware)
