2015-03-19, 19:26
2015-03-19, 22:57
(2015-03-19, 19:24)thebearnecessit Wrote: [ -> ]W previous poster mentioned his external USB HDD wasn't working in android. It needed a powered hub in. The end. I'm going to buy an external external USB HDD. Is there any way I can make sure I buy one that works? For example one that requires less power or something.
My disk Toshiba Stor.E basic 500GB
# OpenELEC - The living room PC for everyone #
# ...... visit http://www.openelec.tv ...... #
OpenELEC (unofficial) Version: 5.0.6
OpenELEC:~ # df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 436896 0 436896 0% /dev
/dev/mmcblk0p1 261868 100352 161516 38% /flash
/dev/mmcblk0p2 14922204 976612 13929208 7% /storage
/dev/loop0 94336 94336 0 100% /
tmpfs 438648 0 438648 0% /dev/shm
tmpfs 438648 6244 432404 1% /run
tmpfs 438648 0 438648 0% /sys/fs/cgroup
tmpfs 438648 4 438644 0% /tmp
tmpfs 438648 228 438420 0% /var
/dev/sda1 488384532 147666564 340717968 30% /var/media/TOSHIBAEXT
2015-03-29, 16:29
For those of you in ATSC land, is there a guide somewhere on how to set-up tvheadend and scan channels. I've looked at several of WeTek's YourTube videos and their forums, but not clear. I'm using their latest OpenELEC build. I've gone into OpenELEC and added (under 'Services') tvheadend, then enabled live TV. Now what? Scan directly from Kodi, or necessary to do something via PC? If latter, instructions somewhere?
2015-03-29, 16:46
(2015-03-29, 16:29)hdmkv Wrote: [ -> ]For those of you in ATSC land, is there a guide somewhere on how to set-up tvheadend and scan channels. I've looked at several of WeTek's YourTube videos and their forums, but not clear. I'm using their latest OpenELEC build. I've gone into OpenELEC and added (under 'Services') tvheadend, then enabled live TV. Now what? Scan directly from Kodi, or necessary to do something via PC? If latter, instructions somewhere?
There's a guide on how to set up tvheadend on the wetek forums, or any other tvheadend guide will do you (it's not platform dependent).
Basically you need to go in to the tvheadend webui via a pc on the same LAN and set it up from there.
2015-03-29, 16:59
Thanks. Think this is the one you're referring to. Will try it.
2015-03-30, 10:20
I purchased a powered hub, which cleared up all issues about my hard-drive not working: http://www.amazon.co.uk/gp/product/B0061...ge_o01_s00
Not as 'neat' as just an external hard-drive, but it does the job until I get around to setting up a NAS
2015-03-30, 19:27
(2015-03-29, 16:59)hdmkv Wrote: [ -> ]Thanks. Think this is the one you're referring to. Will try it.
You can try here too -> http://kodi.wiki/view/WeTek_Play
2015-04-01, 02:02
OpenELEC 5.0.7 released:
Fixed the no signal on HDMI issues
- Fixed an issue when GUI is slow during a video playback
- Other bug fixes and enhancements
[Addon] VDR scanning DVB menu by WeTek
http://www.wetekforums.com/viewtopic.php?f=21&t=749
2015-04-01, 03:13
Thanks, will flash with that, and also re-try ATSC tuner addition via wiki you linked. Just need to find time.
2015-04-02, 02:27
Having trouble figuring out how to set-up tvheadend...
1. Followed this YouTube tutorial, and think I got the OpenELEC/Kodi side fine
2. In tvheadend's configuration, I believe I'm stuck at this. What do I type in for frequency? I'm in U.S. ATSC land
3. I guess this just confirms that #2 was done incorrectly?
Appreciate any help. Also, after above is done correctly, how do you scan for channels (or is it automatic)? How do you then get EPG?
2015-04-03, 22:45
Hi hdmkv,
Find correct tuning data for your State, City...
http://transition.fcc.gov/mb/engineering/dtvmaps/
http://www.tvfool.com/
Your issue is probably you are inserting wrong tuning data.
2015-04-04, 00:18
2015-04-04, 04:25
Noggin, has written the best and easiest TvHeadend Tuner setup Mini Guide I have found....
http://forum.kodi.tv/showthread.php?tid=...pid1929846
Big Hint: Sometimes the TvHeadend preselects for Muxes are pretty out of data.
Your best bet is to choose one of the "Generic" options for pre-defined Muxes if you are having trouble tuning, and then edit and delete from the list, any that fail afterwards.
Second Tip, if you give us your exact location - someone may have the freq values etc available.
2015-04-20, 21:37
[BETA ] VDR Configuration tool from WeTek
Here is beta version of VDR Configuration tool for VDR by WeTek. Originally created for WeTek devices, but this tool can be used with any other Tuner on any Linux XBMC or OpenELEC distro. VDR Configuration allow easy configuration of DVB adapter, scanning and setup of DiSEqC.
This scipt communicate with VDR over restfull api, so prior using VDR Configuration tool, be sure that you enable restfull api at 127.0.0.1 in Configuration part of Plugins in VDR.
Download script.config.vdr.zip
2015-04-23, 09:11
If I bought this would it be possible to record and time shift to my networked server via smb or does it need to be an external hard drive plugged in the side.
