2015-03-09, 21:47
2015-03-09, 22:12
thanks...I guess windows can't see it because of the way the partitions have been created. I just logged onto openelec using putty and found the following:
OpenELEC (unofficial) Version: 5.0.5
OpenELEC:~ # df -h
Filesystem Size Used Available Use% Mounted on
devtmpfs 426.6M 0 426.6M 0% /dev
/dev/mmcblk0p1 255.7M 98.0M 157.7M 38% /flash
/dev/mmcblk0p2 6.9G 487.1M 6.4G 7% /storage
/dev/loop0 92.3M 92.3M 0 100% /
tmpfs 428.4M 0 428.4M 0% /dev/shm
tmpfs 428.4M 4.7M 423.7M 1% /run
tmpfs 428.4M 0 428.4M 0% /sys/fs/cgroup
tmpfs 428.4M 4.0K 428.4M 0% /tmp
tmpfs 428.4M 224.0K 428.1M 0% /var
So I can clearly see disk space is not lost, it's still showing as 6.4GB storage.
I've not had the wetek/openelec for long so not discovered how i can use this space for recording tv etc.
Are there any tutorials on it or is it a case of tinkering
OpenELEC:~ # df -h
2015-03-10, 11:59
There are loads of tutorials on the wetek forum.
2015-03-11, 02:14
(2015-03-09, 22:12)chunky28 Wrote: [ -> ]thanks...I guess windows can't see it because of the way the partitions have been created. I just logged onto openelec using putty and found the following:
OpenELEC:~ # df -h
All bu default, press recording button at RCU and files of recording will be saved to /storage/recordings
When you insert microsd in PC you only see small 256 mb partition where is stored SYSTEM and kernel. Other partition is ext* and not visible by Windows.
2015-03-11, 11:33
I'm no active windows user but i used this tool in the past to access ext* on windows
http://www.ext2fsd.com/
2015-03-12, 01:29
thanks techspaces.....managed to record and noticed it going to the storage area. need to play with the record settings though because it didn't record full screen.
2015-03-17, 16:31
OpenELEC 5.0.6 for WeTek Play released with this changes:
- Fixed an issue when HDMI CEC stops working after a while
- Fixed RCU infinite button presses auto-repeat
- Wi-Fi and LAN LEDs on the from panel are working now as intended
- Other bug fixes and enhancements
microSD card installation: Download
microSD card update: Download
NAND Flash installation: Download
NAND Flash update: Download
2015-03-17, 17:35
I presume I would need a decent sized USB external hard disk if I wanted to use the PVR ( recording TV) functionality? Can anyone give me an example of what size of HDD is working for them.
Also excuse my ignorance but does openelec support Skype and most webcams?
2015-03-17, 22:46
(2015-03-17, 17:35)thebearnecessit Wrote: [ -> ]I presume I would need a decent sized USB external hard disk if I wanted to use the PVR ( recording TV) functionality? Can anyone give me an example of what size of HDD is working for them.Well you can connect almost any USB HDD drive or you can use some NAS for recording.
OpenELEC dont have support for Skype. Skype you can use under Android.
2015-03-18, 14:11
Forgot to add at OpenELEC 5.0.6 is fixed 24p VC1 playback!
2015-03-18, 14:12
(2015-03-18, 14:11)droidelec Wrote: [ -> ]Forgot to add at OpenELEC 5.0.6 is fixed 24p VC1 playback!
Will upgrade at night! Wetek Work Rocks!
2015-03-18, 17:05
I have to say - I've never been happier than since getting the Wetek Play - It's a superb little device
2015-03-18, 22:50
WeTek Play available with 20% (free shipping included) discount for Father's day with WETEKGIFT voucher code.
http://i59.tinypic.com/14t4soh.jpg
2015-03-19, 04:22
(2015-03-18, 22:50)droidelec Wrote: [ -> ]WeTek Play available with 20% (free shipping included) discount for Father's day with WETEKGIFT voucher code.
this is fantastic I will get a second one for my living room, the first one I used in my bedroom and now that LiveTV runs perfect on OpenELEC / KODI I can use it in the living room too.
Thank you for the info droidelec.
2015-03-19, 19:24
W previous poster mentioned his external USB HDD wasn't working in android. It needed a powered hub in. The end. I'm going to buy an external external USB HDD. Is there any way I can make sure I buy one that works? For example one that requires less power or something.
