Full Version: Raspbmc + "Dependencies not met"
Just upgraded to Kodi on my Raspbmc and tried to install Amber skin from here https://github.com/jester-xbmc/skin.amber however I keep getting error message saying 'dependencies not met' and can't get it to work.
Can someone please suggest how I can fix
the skin will only work on nightly builds (Kodi I***).
you're probably using Kodi Helix.
Many thanks for response that explains it then
