2015-01-14, 23:11
(2015-01-14, 22:37)Skyefoxx Wrote: [ -> ]Wow, thank you all for your helpful comment. And yes, I'm a novice (so no offence taken ;-). I have experience with SQL, HTML and XML though, so this is a next step for me...
I will try the easy way and when it works I'll try the 'hard' way also. My goal is not only to get kodi working (by the transferring the xml file) but also to understand the command line codes. I think I'll try this in the weekend, but I will keep this post updated for other users who might benefit from it. Again thank you all, you're helpful and patient.
best regards,
Anton
Have a look here. I've compiled several links and cheatsheets that may be helpful for you as a novice linux user.
http://forum.osmc.tv/showthread.php?tid=5295
