i have an rk3288 android device. I play mkv and avi files. With hardware decoding my mkv hd files play well but my avi files stutters and the just work well with software decoding.
Is there a way (in advancedsettings) to say that kodi plays all my avi files with software decoding and all other files with hardware decoding or my default settings?
AVI and MKV are just file containers. What's more important is what codec is being used. You can use
mediainfo (wiki) to find out the codec info on the files and then manually set different codecs to be software or hardware decoded:
http://kodi.wiki/view/Advancedsettings.xml#video
Set both <stagefright> and <mediacodec> tags, just to be safe.
thank you for your reply. i used mpc for the information.
My Avi files have the following codec:
Video: MPEG4 Video (H264) 720x576 (16:9) 25fps 565kbps [V: h264 high L3.0, yuv420p, 720x576, 565 kb/s]
Audio: MP3 48000Hz stereo 192kbps [A: mp3, 48000 Hz, stereo, 192 kb/s]
My mkv files the following:
Video: MPEG4 Video (H264) 1920x800 23.976fps [V: h264 high L4.1, yuv420p, 1920x800 [default]]
Audio: Dolby AC3 48000Hz 6ch 448kbps [A: Surround [ger] (ac3, 48000 Hz, 5.1, 448 kb/s) [default]]
So both seem to have the same codec with different settings. So avoiding using a special decoder seems not to be possible or? Moreover how should i specify it? The following comment dont tell me how to specify a commit for stagefright and mediacodec:
<!-- -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->
EDIT: Here the mediaInfo Output:
MKV:
Format : Matroska at 6 436 Kbps
Length : 4,75 GiB for 1h 45min 46s 274ms
Video #0 : AVC at 5 860 Kbps
Aspect : 1920 x 800 (2.400)
Audio #0 : AC-3 at 448 Kbps
Infos : 6 Kanäle, 48,0 KHz
AVI:
Format : AVI at 831 Kbps
Length : 391 MiB for 1h 5mn 48s 216ms
Video #0 : AVC at 626 Kbps
Aspect : 720 x 576 (1.778) at 25.000 fps
Audio #0 : MPEG Audio at 192 Kbps
Infos : 2 channels, 48.0 KHz
