(2015-05-16, 12:21)Jeroen Wrote: [ -> ] (2015-05-15, 12:15)PSpaan Wrote: [ -> ]Only problem i have is that i don't see actors pictures. Also when i click on actors picture i does not found info.
In the movie information screen? or in the movies -> actors library ?
Hi Jeroen,
I use pulsar plugin on raspberry 2. I have film info and youtube links but no actor pics and info. Only actor names.
Kind regards, Peter
AWESOME skin on the Raspberry Pi! I kept swapping between SiO2-X and Mimic, and they are good skins also, IMO, but I was mostly sticking with SiO2-X since it seemed to be the smoothest on the Pi...... that is...until I ran into reFocus.
anyone good at skinning able to create a skin for the next up notification service that suits refocus?
This skin is incredible, but how do I add color themes to my android box?
Well, Somehow your custom Includeshome, Kodi15rc2 and Refocus from GIT totally solved the problem. Everything is lightning fast
I did notice a bug though, When making a menu entry for Movies or TVshows linking to "Genre" it does not work. I had to manually edit the command.
Has refocus been removed from the kodi repo? Just installed it a week ago, and now it's not there any more?
Edit:
It was back again after a reload of the kodi repo today. Another strange thing that happened yesterday on another installation where refocus was already installed. Kodi did some automatic addon updates, and suddenly told me refocus no longer had all dependencies met, and wanted me to disable it. I said no to that, but now I wonder if it might just break at some point, if the right conditions should occur?
Jeroen, great skin!
I've been hoping for better implementation of the 'extended info script' in ReFocus. I just tried Mimic. While in the 'info' window of TV or Movies, just use the down arrow on the actor image to launch. Is there a way to add this please?
Thank you
I recently changed tv guide providers to one that includes metadata in the xmltv file. Now the EPG grid-view shows TV show fanart instead of the channel logo. Like most fan-art, it's rectangular (i.e. 16:9 or 9:16) and doesn't fit the square image border. It would be nice to have an option to keep the channel logo in this area.
I have updated to this skin and its brilliant, can't believe it took me this long to find it.
One request to make this skin perfect (for me) , can a banner view be added as I think this will be alot neater view for favourite TV shows.
as far as I know there is already a banner view... am I wrong?
With Refocus and Isengard, I cannot change the sort order of any list, from any media Views to the System menus. All are stuck in Ascending with the options greyed out. Any ideas? I saw someone else mention this back in January but didn't see a solution.
I can change it just fine in every menu in Confluence.
edit: My bad, this seems to be a problem with the Genesis add-on. Not sure why it is different in Refocus and Confluence.
Hi Jeroen, I've made a screensaver for Kodi, unfortunately addons can't use their own Fonts and we have to rely on skins to provide them.
Would you please add one font size?
85
I've tested it already with reFocus and that font size should work perfectly.
If you need any more information please let me know.
Thank you for your help!
Guys, this issue isn't specific to ReFocus but I can't install any addons. I am on OpenElec, have tried many different builds and upgrades etc but I keep getting the same problem.
Here is the pastebin of the log when I try to install the skin:
http://pastebin.com/3mN7TXmq
Any suggestions?
