2017-09-26, 09:46
(2017-09-25, 11:46)wyrm Wrote: [ -> ]Skin Settings/Media Entry Points/ TV entry point was Set to PLAY.(2017-09-25, 05:51)kostaman Wrote: [ -> ]
Once again, hi Kostaman.
Quote:Not entirely sure what you are getting at here, but think it may be as a result of auto starting the TV channel when you click the TV button on the home menu. Find and fix that setting will probably resolve your issues there. On my setup, clicking the TV button on the home screen takes me to a listing of TV channels (the default screen if you have not changed it in the skin settings). From there it is as in most of the rest of the skin. Direction left or ‘menu’ key to bring up screen settings menu. From there you can select EPG, channels, timers, recordings or search. Alternatively you can get to most of the above via the OSD, just is a little more convoluted.
Suggestions for fixing usability are welcome, just remember that sometimes I have no control over how things are done in the PVR system.
Hope this helps,
Wyrm
Changed it to TV Channels.
Listing of TV channels now show up using TV Icon.
It would be perfect if the Channels / Guide / Recordings / Timers / Timer rules
Showed up as shortcuts when TV Button Icon is highlighted before pressing OK.
(Like the movies / tv shows in Movie / TV Library recently added show up)
Excuse my Technical Terminology.
Cheers.
