2020-05-30, 11:50
Actually I just remembered why I unzipped the skin and added the folder manually, when I try to install from zip file I get a dependency error , "resource images classification" unable to install ?
(2020-05-30, 11:50)ontap Wrote: [ -> ]Actually I just remembered why I unzipped the skin and added the folder manually, when I try to install from zip file I get a dependency error , "resource images classification" unable to install ?
(2020-05-30, 12:46)ontap Wrote: [ -> ]OK so, installed resource classification zip , then the skin zip , then enabled skin and ended up with black home screen again , so went back to the other way , installing the skin from kodi interface then adding the two zips and it updated the skin to 1.6.2 , so no probs, but- as yet cant get a widget to show on shelf tried various options inc creating a couple of playlists , but am stuck with to movie and tv icon atm. Its not urgent , you crack on with your changes and I will switch to the new skin when sorted , looking forward to it.@ontap ,
(2020-06-29, 19:30)ontap Wrote: [ -> ]Hi mate , downloaded your latest from github yesterday, cant get the lite theme? theme is greyed out, I tried changing the color to lite and even flat lite, but all that does is make all the list panels even darker so you can barely see the text ?
(2020-07-04, 17:39)wyrm Wrote: [ -> ]@ontap ,
well sport you opened a can of worms there. I would like to say its the fault of Embuary helper script, but does not seem quite that simple. Trying to find a solution, but it might take a while.
The playlists and favourites widgets are highly customisable and very powerful, BUT it is possible for a user to give the system some crazy stuff to deal with. For example, I managed to have a widget that had pictures, videos and .nfo files displayed (the .nfo's did nothing). Will have to try to come up with a way to filter the widgets so that only video and music files are shown. Think the issue with episodes relates to this as I think Embuary helper is agragating multiple episodes together if there are multiples for each show shown in the widget.
Will investigate further
Wyrm
