Full Version: NetfliXBMC - version 1.3.9
I am having trouble with the latest NetfliXBMC, version 1.3.9
The navigation of the Netflix is working once again, thank you.
I am having trouble playing the vidoes unfortunately.
I get this error in the log file:
21:00:56 T:140505764546304 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'sqlite3.OperationalError'>
Error Contents: no such table: cookies
File "/home/jduda/.kodi/addons/plugin.video.netflixbmc/default.py", line 1082, in <module>
playVideoMain(url)
File "/home/jduda/.kodi/addons/plugin.video.netflixbmc/default.py", line 617, in playVideoMain
launchChrome(url)
File "/home/jduda/.kodi/addons/plugin.video.netflixbmc/default.py", line 662, in launchChrome
chrome_cookies.inject_cookies_into_chrome(session, os.path.join(userdir, "Default", "Cookies"))
File "/home/jduda/.kodi/addons/plugin.video.netflixbmc/resources/lib/chrome_cookies.py", line 41, in inject_cookies_into_chrome
conn.execute(sql)
OperationalError: no such table: cookies
21:00:56 T:140507990239616 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
I tried resetting the cache, cookies, and resetting NetfliXBMC.
It appears something happened to the sq3lite database?
How can I resolve?
I installed from here:
https://www.alelec.net/kodi/repository.alelec.zip
Thanks for the great plugin!
Regards,
Jim
1.3.8 was working fine for me then add-on got updated today to 1.3.9 and I'm having the same issue. Unistalled add-on and reinstalled from repo but it put 1.3.9 on again. How can I get 1.3.8 reinstalled?
in your \packages folder under addons will find previous version of addons
Peppe
Here is a pastebin log file for the issue with 1.3.9.
http://pastebin.com/PqT9ERXh
I will try to downgrade to 1.3.8
Regards,
Jim
In my addons\packages directory, I have this:
plugin.video.netflixbmc-1.3.4.zip
How do I revert back to 1.3.8 then?
should be there,
if not, you can't revert to 1.3.8 version.
Peppe
The plugin.video.netflixbmc-1.3.8.zip file was not in my addons\packages directory either. I just switched the 1.3.9 plugin to use IE instead of Chrome and the script error is gone and seems to work fine under IE. I read that that only IE 11 on Win8 would work, but I'm using IE 10 on Win7, seems to work OK.
(2015-01-12, 23:07)turd Wrote: [ -> ]The plugin.video.netflixbmc-1.3.8.zip file was not in my addons\packages directory either. I just switched the 1.3.9 plugin to use IE instead of Chrome and the script error is gone and seems to work fine under IE. I read that that only IE 11 on Win8 would work, but I'm using IE 10 on Win7, seems to work OK.
Thanks for the tip - Chrome doesn't work for me either in 1.3.9, but Netflixbmc works just fine with IE11/Win7.
Version 1.3.11 showed up and everything appears to be working again.
Thanks for such an awesome plugin for Kodi.
Regards,
Jim
First time user to XBMC and started finding all the goodies inside.
I have installed Nexflix 1.3.4 and lots of errors. after looking online the fix was to upgrade to 1.3.8 using "You need to use corana's custom repo: http://www.alelec.net/kodi/repository.alelec.zip"
after installing the repo and trying to install the new netflix it failed to install then I noticed it was 1.3.11
is there a trick to install the 1.3.11 or is there a known error and I need to figure out how to get the 1.3.8?
Thank you
EDIT: UPDATE, So I kept looking and after downloading many failed atempts I was able to get this: https://github.com/andrewleech/plugin.vi...master.zip
installed with zip from download locations
Netflix 1.3.11 for XBMC installed and working with no problems
