2015-01-09, 15:22
Hi, i'm possible going mad, or something has changed with Kodi Helix? Befor upgrading to Helix i decided share my libray using a SQL database (i followed the instructions set out in the Wiki). I exported my libraray then imported them using the "use local data" for scraping, i guess this uses the locally stored NFO files, or went well, then upgraded to helix.... all went well....
I added a new movie to my shared drive and tried to update the library manually. My movie wasn't added or scrapped, when navigation to file manager i can see the file.
I can only presume this is because i left the settings as "use local data" when scraping and not one of the built in scrapers.
I'm trying to change this, in Gothan I’m pretty sure when in Movies, by clicking the context menu, an option to "changes content" was available, this enabled me to change whether the source was music, movies etc and also select a different scraper... has this moved? how do i do this now?
