2015-01-09, 19:12
Hello again!
I recently upgraded from an old Ubuntu (12.something) running XBMC Gotham (13.something) to Linux Mint 17.1 (Rebecca), and I've run into a couple of issues to which I not only have no solution, but also not much of a clue where to even start looking. Maybe somebody here can give me a hint or point me into the right direction? (Wouldn't even surprise me if a single checkbox could help me out… ;-) )
So Kodi was easy enough to install and get working, and works great as expected—with two exceptions. This post's about the second one: I can't seem to get hardware video acceleration working again as it did before.
A couple of years ago, I decided that my home server would become the hub in my living room: a big TV would be its monitor and XBMC was the software of choice. Since the CPU is probably under-powered when it comes to decoding full-HD video and such, I installed a graphics card (I opted for a Radeon HD 6450 because of external factors and constraints) to offload the decoding.
And it worked great: after activating VDPAU and VAAPI, I've never had any issues with any video again!
That changed after my upgrade. Of course, I installed the proprietary driver for the graphic card (not sure how far along the open source ones are, but I remember having had trouble with those earlier) and played around with the settings under "System -> Settings -> Video -> Acceleration", but alas, to no avail: Even "easier" videos which I just last week watched without issues, now jerk and stutter as soon as the camera moves around a bit…
Did I forget to switch something on (or off)? Or does the issue lie with the OS, or maybe the (proprietary) drivers?
(Is there a way to check if the decoding is being done via software or hardware, maybe through some debugging option?)
I know it's not the hardware since, as I said, the exact same hardware used to work a couple of days ago before the upgrade.
Any ideas?
Thanks for your help!
Nicola
PS: One more thing that might be of interest: With the old setup, when I would connect via VNC, I would stare at a black screen when XBMC was running—it seemed that when XBMC started, something "took over" the rendering (the graphic card or, rather, its drivers?) so that my VNC client couldn't display anything anymore. When XBMC wasn't running, VNC worked flawlessly. On the new system, VNC works just fine and is displayed correctly even with Kodi running: Is this maybe a sign that something is indeed set up and running differently? That hardware decoding isn't running and thus the graphics card isn't "taking over" the decoding?
Any ideas?
Nicola
