2015-01-10, 02:04
Hi There!
I cancelled our TV subscription in the fall and installed an antenna in our attic over the holidays. We currently get around 30 OTA HD channels, almost 20 with excellent reception (4 or 5 bars out of 5). At some point I'm going to revisit this setup to see if I can do any better. Depending on how this works, I may later try to add an FTA Satellite feed.
In the meantime, I would like to setup a system to provide:
We currently have an Apple TV hooked up so that we can watch NetFlix and stream content off of the internet. We rarely (almost never) use it to for iTunes content. I've been disappointed with the streaming of browser based feeds from my MacBook; but, this is a definite 'must have' capability. Not that we can stream from a laptop or tablet but that we can stream webcasts via the HTPC to the TV.
We also have a Sony Home Theatre system. We will sometimes use it to watch a DVD, listen to the radio or listen to music. I'm basically the only one to use it as my wife doesn't like the 'surround sound' audio. I'm of the opinion that music isn't loud enough until you feel it in your chest while she prefers the sound to be at the lowest discernible level.
We have iOS, android, OS X, & Windose devices in the home. Once this is up & running, we would like to put a wifi enabled TV in the master bedroom and be able to watch content without having to install / configure another device.
I have a DIY Ubuntu tower that I'm planning on repurposing for this system. I envision replacing the Apple TV & Sony device with one home built system. This workstation (micro ATX MB, 8 GB RAM, 1 TB HDD, can't remember what CPU I used) that I will reconfigure for this project supports HDMI output, GB Ethernet, Optical S/PDIF audio output, and 8 channel audio I/O.
So, based on my reading to this point (multiple threads on this site, Ned Scott's Newbie PVR Guide, Advocate99's Complete Setup Guide, lifehacker's How to Watch and Record Live TV, ...), I think this is doable; but, have a few questions.
If I understand it correctly, at a high level, I will need to:
My questions are:
Thanks for any input or advice you may be able to share!
- a channel guide so that it's easier for my wife to pick something to watch or record
- the ability to pause & rewind live TV
- the ability to watch feeds from the internet, primarily NetFlix & webcasts
- a whole home PVR (the ability to record the OTA HD stations and replay anywhere in the house on any device)
- easy to navigate, control using a smart phone or tablet application (we find the Apple TV NetFlix interface sadly lacking to search for content)
- the ability to watch and record multiple (at least 2 preferably 3 or 4) channels simultaneously
- the ability to easily use either the native TV or external speakers
- the ability to stream live sports (primarily only interested in NFL & NHL) - I understand Kodi has plug-in for this
- build the HTPC, with at least one TV tuner card with dual coax antenna inputs
- install & configure Ubuntu Server
- install & configure TVHeadEnd
- install & configure Kodi
- setup, install & configure HDHomeRun
My questions are:
- Am I out to lunch on anything I'm attempting to accomplish?
- Can I serve content to any device in the house without having to instal/configure a device for each TV?
- Is HDHomeRun the only way to share the content throughout the house? Or is there a SW solution alternative that will allow me to use my wifi and forgo purchasing another device?
