Full Version: Random image on home - icons
Hello
Fantastic skin ! thanks for the work.
I made it my default skin.
It seems that it is not possible to set a random image on home - icons as it is possible for backgrounds
Is there some kind of limitation or can it be done ?
Thanks for your support
Regards
The skinning engine does not allow multi-image controls inside containers. It could be technically possible rewriting from scratch the home menu. But it would require a lot if time and would make it very complicated. Too much work for such a small feature.
Tgx
Thanks for your answer.
It would be a nice feature but i understand the constraint
